man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
panel_move(3CURSES)
Name
panel_move, move_panel - move a panels window on the virtual screen
Synopsis
cc [ flag ... ] file ... –lpanel –lcurses [ library .. ]
#include <panel.h>
int move_panel(PANEL *panel, int starty, int startx);
Description
move_panel() moves the curses window associated with panel so that its upper left-hand corner is at starty, startx. See usage note, below.
Return Values
OK is returned if the routine completes successfully, otherwise ERR is returned.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curses(3CURSES), panel_update(3CURSES), panels(3CURSES), attributes(5)
Notes
For panels windows, use move_panel() instead of the mvwin() curses routine. Otherwise, update_panels() will not properly update the virtual screen.
The header <panel.h> automatically includes the header <curses.h>.
