man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
flash(3XCURSES)
Name
beep, flash - activate audio-visual alarm
Synopsis
cc [ flag... ] file... –I /usr/xpg4/include –L /usr/xpg4/lib \
–R /usr/xpg4/lib –lcurses [ library... ]
c89 [ flag... ] file... –lcurses [ library... ]
#include <curses.h>
int beep(void);
int flash(void);
Description
The beep() and flash() functions produce an audio and visual alarm on the terminal, respectively. If the terminal has the capability, beep() sounds a bell or beep and flash() flashes the screen. One alarm is substituted for another if the terminal does not support the capability called (see terminfo(4) bel and flash capabilities). For example, a call to beep() for a terminal without that capability results in a flash.
Return Values
These functions always return OK.
Errors
None.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
See also
libcurses(3XCURSES), terminfo(4), attributes(5), standards(5)
