man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
set_max_field(3CURSES)
Name
form_field_buffer, set_field_buffer, field_buffer, set_field_status, field_status, set_max_field - set and get forms field attributes
Synopsis
cc [ flag... ] file... –lform –lcurses [ library... ]
#include <form.h>
int set_field_buffer(FIELD *field, int buf, char *value);
char *field_buffer(FIELD *field, int buf);
int set_field_status(FIELD *field, int status);
int field_status(FIELD *field);
int set_max_field(FIELD *field, int max);
Description
set_field_buffer() sets buffer buf of field to value. Buffer 0 stores the displayed contents of the field. Buffers other than 0 are application specific and not used by the forms library routines. field_buffer() returns the value of field buffer buf.
Every field has an associated status flag that is set whenever the contents of field buffer 0 changes. set_field_status() sets the status flag of field to status. field_status() returns the status of field.
set_max_field() sets a maximum growth on a dynamic field, or if max=0 turns off any maximum growth.
Return Values
field_buffer() returns NULL on error.
field_status() returns TRUE or FALSE.
set_field_buffer(), set_field_status(), and set_max_field() return one of the following:
E_OK
Thefunction returned successfully.
E_SYSTEM_ERROR
System error
E_BAD_ARGUMENT
An argument is incorrect.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curses(3CURSES), forms(3CURSES), attributes(5)
Notes
The header <form.h> automatically includes the headers <eti.h> and <curses.h>.
