man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
start_color(3XCURSES)
Name
can_change_color, color_content, COLOR_PAIR, has_colors, init_color, init_pair, pair_content, PAIR_NUMBER, start_color, COLOR_PAIRS , COLORS - manipulate color information
Synopsis
cc [ flag... ] file... –I /usr/xpg4/include –L /usr/xpg4/lib \
–R /usr/xpg4/lib –lcurses [ library... ]
c89 [ flag... ] file... –lcurses [ library... ]
#include <curses.h>
bool can_change_color(void);
int color_content(short color, short *red, short *green, short *blue);
int COLOR_PAIR(int n);
bool has_colors(void);
int init_color(short color, short red, short green, short blue);
int init_pair(short pair, short f, short b);
int pair_content(short pair, short *f, short *b);
int PAIR_NUMBER(int value);
int start_color(voidextern int COLOR_PAIRS;
extern int COLORS;
Description
These functions manipulate color on terminals that support color.
Querying Capabilities
The has_colors() function indicates whether the terminal is a color terminal. The can_change_color() function indicates whether the terminal is a color terminal on which colors can be redefined.
Initialization
The start_color() function must be called to enable use of colors and before any color manipulation function is called. The function initializes eight basic colors (black, red, green, yellow, blue, magenta, cyan, and white) that can be specified by the color macros (such as COLOR_BLACK) defined in <curses.h>. The initial appearance of these colors is unspecified.
The function also initializes two global external variables:
  • COLORS defines the number of colors that the terminal supports. See Color Identification below. If COLORS is 0, the terminal does not support redefinition of colors and can_change_color() will return FALSE.
  • COLOR_PAIRS defines the maximum number of color-pairs that the terminal supports. See User-defined Color Pairs below.
The start_color() function also restores the colors on the terminal to terminal-specific initial values. The initial background color is assumed to be black for all terminals.
The init_color() function redefines color number color, on terminals that support the redefinition of colors, to have the red, green, and blue intensity components specified by red, green, and blue , respectively. Calling init_color() also changes all occurrences of the specified color on the screen to the new definition.
The color_content() function identifies the intensity components of color number color. It stores the red, green, and blue intensity components of this color in the addresses pointed to by red, green, and blue, respectively.
For both functions, the color argument must be in the range from 0 to and including COLORS−1. Valid intensity value range from 0 (no intensity component) up to and including 1000 (maximum intensity in that component).
Calling init_pair() defines or redefines color-pair number pair to have foreground color f and background color b. Calling init_pair() changes any characters that were displayed in the color pair's old definition to the new definition and refreshes the screen.
After defining the color pair, the macro COLOR_PAIR(n) returns the value of color pair n. This value is the color attribute as it would be extracted from a chtype. Controversy, the macro COLOR_NUMBER( value) returns the color pair number associated with the color attribute value.
The pair_content() retrieves the component colors of a color-pair number pair. It stores the foreground and background color numbers in the variables pointed to by f and b, respectively.
With init_pair() and pair_content(), the value of pair must be in a range from 0 to and including COLOR_PAIRS−1. Valid values for f and b are the range from 0 to and including COLORS−1.
Parameters
color
Is the number of the color for which to provide information (0 to COLORS−1).
red
Is a pointer to the RGB value for the amount of red in color.
green
Is a pointer to the RGB value for the amount of green in color.
blue
Is a pointer to the RGB value for the amount of blue in color.
n
Is the number of a color pair.
pair
Is the number of the color pair for which to provide information (1 to COLOR_PAIRS−1).
f
Is a pointer to the number of the foreground color (0 to COLORS−1) in pair.
b
Is a pointer to the number of the background color (0 to COLORS−1) in pair.
value
Is a color attribute value.
Return Values
The has_colors() function returns TRUE if the terminal can manipulate colors. Otherwise, it returns FALSE.
The can_change_color() function returns TRUE if the terminal supports colors and is able to change their definitions. Otherwise, it returns FALSE.
Upon successful completion, the other functions return OK. Otherwise, they return ERR.
Errors
No errors are defined.
USAGE
USAGE
To use these functions, start_color() must be called, usually right after initscr(3XCURSES).
The can_change_color() and has_colors() functions facilitate writing terminal-independent applications. For example, a programmer can use them to decide whether to use color or some other video attribute.
On color terminals, a typical value of COLORS is 8 and the macros such as COLOR_BLACK return a value within the range from 0 to and including 7. However, applications cannot rely on this to be true.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
See also
attroff(3XCURSES), delscreen(3XCURSES), initscr(3XCURSES), libcurses(3XCURSES), attributes(5), standards(5)
