IPv4 format: 10.8.183.106
IPv6 format: fec0:a:8:b7:214:4fff:5eca:5f7e/64
Verify that a physical Ethernet connection between your network and the NET MGT port on your Oracle server or blade chassis is established.
For a local (non-network) connection to Oracle ILOM, ensure that the IPv4 state is enabled, or both the IPv4 and IPv6 states are enabled for dual-stack network environments.
Use a command-line network tool, like Ping, to verify connectivity to the network.
For IPv6 management connections, ensure that the IPv6 address in the URL is enclosed by brackets.
For example:
Web interface URL format:
https://[fe80::221:28ff:fe77:1402]
CLI download file URL format:
-> load -source tftp://[fec0:a:8:b7:214:rfff:fe01:851d]desktop.pkg
