Go to main content
Oracle® ILOM Getting Started Guide Firmware Release 3.2.x
Exit Print View
Updated: May 2016
Reset Oracle ILOM on a Managed Device
Before You Begin
  • You need Reset and Host Control (r) privileges to reset Oracle ILOM on the server SP or CMM.
  • Resetting Oracle ILOM on a managed device does not have any affect on the operating system.
  • Resetting Oracle ILOM on a server SP or CMM disconnects the current Oracle ILOM session(s) and renders the management connection unmanageable until the reset process completes.
You can reset the Oracle ILOM on the SP or CMM using the CLI or web interface.
  • Reset Oracle ILOM SP or CMM - Web Procedure 1
  • Reset Oracle ILOM SP or CMM - CLI Procedure 2
  1. Reset Oracle ILOM SP or CMM — Web Procedure
    To reset Oracle ILOM from the server SP or CMM web interface, perform one of the following:
    • For the server SP, click System Information > Maintenance > Reset SP, and then click the Reset button.
    • For the CMM, click System Information > Maintenance > Reset Components, and then select the appropriate chassis component from the table and click the Reset button.
  2. Reset Oracle ILOM SP or CMM — CLI Procedure
    To reset the Oracle ILOM server SP, CMM, or blade SP, type one of the following:
    reset /SP
    reset /CMM
    reset /Servers/Blades/BLn/SP
Related Information
