Before You Begin
The power statistics in Oracle ILOM enables you to view the power usage on a managed device over the last 15-, 30-, and 60-second intervals. It also identifies the date and time for the peak power wattage usage on the managed device.
The power history in Oracle ILOM enables you to view the minimum, average, and maximum power usage on a managed device for the last hour or 14 days. It also identifies the date and time for the peak power wattage usage on the managed device.
The power consumption statistics and history data in Oracle ILOM are viewable from the server SP web interface, CMM web interface, and the CMM CLI. They are not viewable from the server SP CLI.
To view the power consumption statistics and history for a managed device from the web interface or the CLI, perform one of these procedures:
View power statistics and history – Web Procedure 1
View power statistics and history – CLI Procedure 2
The power usage statistics appear in 15-, 30-, and 60-second intervals for the managed device.
Additionally, for the CMM power statistics view only, you can toggle the view between the chassis power usage and the blade server power usage.
The power history for the minimum, average, and maximum power usage appears for the managed device.
You can toggle the view between one hour and 14 days.
Additionally, for the CMM power history view only, you can toggle the view between the chassis power usage and the blade server power usage.
