Before You Begin
On most server SPs and CMMs, you can create up to 10 local user accounts. On some SPARC SPs and CMMs, you can create up to 60 local user accounts.
You can use the CLI, web interface, SNMP interface, or IPMI interface to manage the server SP or CMM local user accounts. The following procedure identifies how to perform this task using the web interface and the CLI. To locate instructions on how to perform this task using an SNMP or IPMI interface, see the Related Information section following this procedure.
The following procedure assumes you are logged in to Oracle ILOM as a root user. For root user login instructions, see Log In to Oracle ILOM.
To add new local user accounts to Oracle ILOM, perform one of the following procedures:
Add new local user accounts – Web Procedure 1
Add new local user accounts – CLI Procedure 2
The Add User dialog box appears.
Oracle ILOM enables you to select one of three user role profiles from the web interface: Administrator, Operator, or Advanced. For a description of each user role profile, see Example 1, Oracle ILOM User Profile and Role Descriptions.
For example:
For example:
To grant all read and write privileges to user5 on the server SP, type:
For more information about the user roles and privileges supported in Oracle ILOM, see the following table.
