Before You Begin
If required by your platform, shut down the host operating system prior to updating the firmware image on the server SP.
You need Admin (a) role privileges to update the firmware on an Oracle server SP or CMM.
You can initiate the firmware update process from the web interface, CLI, or SNMP client.
The procedures in this section describe how to initiate the firmware update process from the web interface and CLI. To locate instructions on how to perform this task using an SNMP client, or how to manage firmware updates across a modular chassis system, see the Related Information section following these instructions.
The firmware update process takes several minutes to complete. During this time, do not perform other Oracle ILOM tasks. When the firmware update is complete, the system reboots.
To initiate the firmware update process from the SP or CMM CLI or web interface:
For the web interface, click System Information > Summary, and view the property value for the System Firmware Version in the General Information table.
For the CLI, at the command prompt, type: version
For information about the numbering scheme used to identify a firmware version, refer to the Oracle ILOM Feature Updates and Release Notes, Firmware Release 3.2.x.
For detailed instructions on downloading software updates from the My Oracle Support web site, refer to the Oracle ILOM Feature Updates and Release Notes.
For a web interface firmware update, copy the image to the system on which the Oracle ILOM web browser is running.
For a CLI firmware update, copy the image to a server that is accessible from your network.
For detailed instructions about using the firmware update dialogs, refer to Oracle ILOM Administrator's Guide for Configuration and Maintenance.
-> load -source supported_protocol://server_ip/path_to_firmware_image/ filename.xxx
For detailed instructions about using the CLI firmware update prompts, refer to Oracle ILOM Administrator's Guide for Configuration and Maintenance.
