Modify the Power State on a Managed Device
Before You Begin
To modify the power state on a server SP or CMM, you can use the Oracle ILOM CLI or web interface.
Modify Managed Device Power State – Web Procedure
In the SP or CMM web interface, click Host Management -> Power Control.
Power Control page appears.
Note -
For CMM only, click the radio button adjacent to the chassis device listed in the Remote Power Control table.
To set the power state on a managed device, select one of the following options:
Reset
– This SP-specific option power-cycles the managed server, while keeping power applied to system components (such as disk drives and so on).
Graceful Reset
– This SPARC SP specific option gracefully shuts down the host OS prior to power-cycling the managed SPARC server.
Immediate Power Off
– This option immediately powers off the managed device.
Graceful Shutdown and Power Off
– This option gracefully powers down the OS prior to powering off the managed device.
Power On (default setting) – This option applies full power to the managed device.
Power Cycle
– This option powers off the managed device, then applies full power to the managed device.
Modify Managed Device Power State – CLI Procedure
To set the power state on a managed device from the SP or CMM CLI, perform one of the following actions:
