Chapter 1 Oracle ZFS Storage Appliance Overview
Chapter 3 Initial Configuration
Chapter 4 Network Configuration
Chapter 5 Storage Configuration
Chapter 6 Storage Area Network Configuration
Chapter 8 Setting ZFSSA Preferences
Chapter 10 Cluster Configuration
Chapter 12 Shares, Projects, and Schema
Chapter 16 Maintenance Workflows
Oracle Exadata Database Machine Backup
Manual Configuration of a Sun ZFS Storage Appliance
Configuring Networks, Pools, and Shares
Configuring Oracle RMAN and the Oracle Database Instance
Configuring Oracle Exadata for a Sun ZFS Storage Appliance
Configure Exadata Configuring Oracle Exadata for a Sun ZFS Storage Appliance
Setting Up the Directory Structure to Mount the Shares on the Host
Updating oranfstab to Access ZFS Storage Appliance Exports
Mounting the Shares on the Host
Setting the Ownership of the Mounted Shares
Oracle SPARC SuperCluster Backup
Configuring the ZFS Storage Appliance for Backup
Configuring the ZFS Storage Appliance InfiniBand Datalinks
Configuring the Oracle SPARC SuperCluster InfiniBand Switches to Add the ZFS Storage Appliance
Configuring ZFS Storage Appliance Networking for Single IP Connection
Configuring ZFS Storage Appliance Networking for an Active-Active Configuration
Configuring the ZFS Storage Appliance Storage Pool
Configuring the ZFS Storage Appliance Shares
Configuring the ZFS Storage Appliance DTrace Analytics
Configuring the Client NFS Mount
Tuning the Solaris 11 Network and Kernel
Configuring Oracle Direct NFS (dNFS)
Tuning the Oracle Database Instance for Oracle RMAN Backup and Restore
Creating Dedicated Services for Oracle RMAN Operations
Configuring Oracle SPARC SuperCluster for ZFS Storage Appliance Backup
Configure SSC Configuring Oracle SPARC SuperCluster for ZFS Storage Appliance Backup
Enabling the NFS Client Service
Oracle Intelligent Storage Protocol
Set the Optimal file record size
Use either ZFS Latency or Throughput write mode for each request
Sun ZFS Storage Appliance Network File System Plug In for Oracle Solaris Cluster
Sun ZFS Storage Appliance Plug-in for Oracle Solaris Cluster Geographic Edition
Sun ZFS Storage Management Plug-In for Oracle Enterprise Manager Grid Controller
Configure for Oracle Enterprise Manager Monitoring
Unconfigure Oracle Enterprise Manager Monitoring
Oracle Virtual Machine Storage Connect Plug-in for the Sun ZFS Storage Appliance
FC support with Symantec's 'DMP' / Storage Foundation
FC support for Symantec's Storage Foundation 5.1RP2 and greater for the following OS versions
Sun ZFS Storage 7000 Storage Replication Adapter for VMware Site Recovery Manager
Volume Shadow Copy Services (VSS) for Microsoft operating systems provides a framework to allow volume backups to be performed while applications on a system continue to write to the volumes. VSS provides a consistent interface that allows coordination between user applications that update data on disk (VSS writers) and those that back up applications (VSS requesters). Specifically, VSS provides:
A backup infrastructure that coordinates applications with file system activities
A location to create point in time, coalesced copies known as shadow copies
The Sun ZFS Storage Appliance Provider For Volume Shadow Copy Service Software is a VSS hardware provider that allows the Sun ZFS Storage Appliance to take consistent snapshots for Windows hosts which are using block targets. VSS coordinates snapshots to ensure block data is consistent. The provider communicates with a set of workflows on the appliance to coordinate taking of snapshots as seen from the application. It works over both iSCSI and Fibre Channel.
The Sun ZFS Storage Appliance Provider For Volume Shadow Copy Service Software is installed on hosts that require this functionality and coordination between applications. Complete documentation for this application integration is packaged with the downloaded components in the form of a ReadMe file. The provider software and readme file are available as part of the Sun ZFS Storage 7000 Software Providers and Plug-Ins patch on the Oracle Technology Network]. More information on VSS is available on the Microsoft web site, including this [http://msdn.microsoft.com/en-us/library/aa384649%28VS.85%29.aspx overview.
