Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Save the Configuration to a File
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
This task describes how to save the initial configuration file to flash or to a remote location.
See Basic SEFOS Topology for the topology for this task.
See Connect to SEFOS.
SEFOS-1# ping 12.0.0.100
SEFOS-1# write startup-config
SEFOS-1# copy startup-config tftp://12.0.0.100/switch.conf_date SEFOS-1#
