Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
This task describes how to save configurations even after restarting the switch.
See Switching Feature Topology for the topology of this task.
SEFOS-1# write startup-config
This process might take a few seconds. You see the message [OK] when the configurations have been successfully saved.
SEFOS-1# exit Connection closed by foreign host. cd: The session with /TOR/fs_cli has ended.
-> cd /SP
-> reset Are you sure you want to reset /SP (y/n)? y Performing reset on /SP ...
See Connect to SEFOS.
SEFOS-1# show etherchannel summary Port-channel Module Admin Status is enabled Port-channel Module Oper Status is enabled Port-channel System Identifier is 00:14:4f:6c:69:ee Flags: D - down P - in port-channel I - stand-alone H - Hot-standby (LACP only) AD - Admin Down AU - Admin Up OD - Operative Down OU - Operative Up Number of channel-groups in use: 1 Number of aggregators: 1 Group Port-channel Protocol Ports ----------------------------------------------------------------- 100 Po100(P)[AU,OD] LACP Ex0/21(D),Ex0/22(P) ...
Once SEFOS-1 and SEFOS-2 are both restarted, SEFOS comes up with all the previous configurations.
