Understanding SuperCluster Software
Identify the Version of SuperCluster Software
Controlling SuperCluster M6-32
Powering Off SuperCluster M6-32 Gracefully
Shut Down the Oracle Solaris Cluster
Shut Down the Enterprise Controller (Ops Center)
Shut Down the OS on the Compute Servers
Shut Down the ZFS Storage Appliance
Power Off the Switches and Racks
Power Off SuperCluster M6-32 in an Emergency
Monitoring SuperCluster M6-32 (OCM)
Monitoring the System With ASR
Configure ASR on the Compute Servers (Oracle ILOM)
Configure SNMP Trap Destinations for Storage Servers
Configure ASR on the ZFS Storage Appliance
Configuring ASR on the Compute Servers (Oracle Solaris 11)
Enable the HTTP Receiver on the ASR Manager
Enable HTTPS on ASR Manager (Optional)
Register Compute Servers With Oracle Solaris 11 or Database Domains to ASR Manager
Approve and Verify ASR Asset Activation
Change ssctuner Properties and Disable Features
Configuring CPU and Memory Resources (osc-setcoremem)
Minimum and Maximum Resources (Dedicated Domains)
Supported Domain Configurations
Plan CPU and Memory Allocations
Display the Current Domain Configuration (osc-setcoremem)
Display the Current Domain Configuration (ldm)
Change CPU/Memory Allocations (Socket Granularity)
Change CPU/Memory Allocations (Core Granularity)
Access osc-setcoremem Log Files
Revert to a Previous CPU/Memory Configuration
Remove a CPU/Memory Configuration
Obtaining the EM Exadata Plug-in
Known Issues With the EM Exadata Plug-in
Configuring the Exalogic Software
Prepare to Configure the Exalogic Software
Enable Domain-Level Enhancements
Enable Cluster-Level Session Replication Enhancements
Configuring Grid Link Data Source for Dept1_Cluster1
Runtime Connection Load Balancing
Secure Communication With Oracle Wallet
Create a Grid Link Data Source on Dept1_Cluster1
Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1
Configure the Database to Support IB
Create an SDP Listener on the IB Network
Administering Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Create a Snapshot of a Boot Environment
Remove Unwanted Boot Environments
Monitor Write-through Caching Mode
This is a high-level description of the tasks you perform to configure ASR on SuperCluster. For more details, refer to ASR documentation. See ASR Resources.
Create or verify your MOS account at http://support.oracle.com.
Ensure that your MOS account is correctly set up:
Oracle Premier Support for Systems or Oracle/Sun Limited Warranty
Technical contact responsible for SuperCluster system
Valid shipping address for parts
Designate a standalone system to serve as the ASR Manager and install the ASR Manager software.
The server must run either Oracle Solaris or Linux, and Java
You must have superuser access to the ASR Manager system.
To download ASR Manager software, go to:http://www.oracle.com/technetwork/systems/asr/downloads
For installation instructions, refer to the ASR documentation that corresponds to the version of ASR Manager you plan to install. The documentation is available at:
Ensure that the ASR Manager server has connectivity to the Internet using HTTPS.
You might need to open certain ports to your datacenter. For more information, see the Oracle ASR Security White paper, located here:
(Optional) Obtain these documents:
Oracle SuperCluster M6-32 System Site Checklists
Oracle SuperCluster M6-32 System Configuration Worksheets
The information in these documents can provide helpful information when you configure SuperCluster for ASR.
Configure and activate SuperCluster ASR assets.
Refer to ASR documentation and see Configuring ASR on the Compute Servers (Oracle Solaris 11).
Note - An active ASR Manager must be installed and running before you configure ASR assets.
Note - To monitor Oracle Solaris 10 assets, you must install the latest STB bundle on SuperCluster. Refer to Doc ID 1153444.1 to download the latest STB bundle from MOS: https://support.oracle.com
Approve ASR assets in MOS.
Follow the instructions in the ASR documentation.
