Skip Navigation Links
Exit Print View
Oracle SuperCluster M6-32
Owner's Guide: Administration
search filter icon
search icon
Document Information
Using This Documentation
Product Documentation Library
Feedback
Understanding SuperCluster Software
Identify the Version of SuperCluster Software
SuperCluster Tools
Controlling SuperCluster M6-32
Cautions
Power On SuperCluster M6-32
Powering Off SuperCluster M6-32 Gracefully
Shut Down the Oracle Solaris Cluster
Shut Down the Enterprise Controller (Ops Center)
Shut Down the Database
Shut Down the Storage Servers
Power Off the Storage Servers
Shut Down the LDoms
Shut Down the OS on the Compute Servers
Shut Down the ZFS Storage Appliance
Power Off the Switches and Racks
Power Off SuperCluster M6-32 in an Emergency
Monitoring SuperCluster M6-32 (OCM)
OCM Overview
Access OCM Documentation
Monitoring the System With ASR
ASR Overview
ASR Resources
ASR Installation Overview
Configure ASR on the Compute Servers (Oracle ILOM)
Configure SNMP Trap Destinations for Storage Servers
Configure ASR on the ZFS Storage Appliance
Configuring ASR on the Compute Servers (Oracle Solaris 11)
Enable the HTTP Receiver on the ASR Manager
Enable HTTPS on ASR Manager (Optional)
Register Compute Servers With Oracle Solaris 11 or Database Domains to ASR Manager
Approve and Verify ASR Asset Activation
Tuning SuperCluster M6-32
ssctuner Overview
Monitor ssctuner Activity
View Log Files
Change ssctuner Properties and Disable Features
Install ssctuner
Enable ssctuner
Configuring CPU and Memory Resources (osc-setcoremem)
osc-setcoremem Overview
Minimum and Maximum Resources (Dedicated Domains)
Supported Domain Configurations
Plan CPU and Memory Allocations
Display the Current Domain Configuration (osc-setcoremem)
Display the Current Domain Configuration (ldm)
Change CPU/Memory Allocations (Socket Granularity)
Change CPU/Memory Allocations (Core Granularity)
Park Cores and Memory
Access osc-setcoremem Log Files
View the SP Configuration
Revert to a Previous CPU/Memory Configuration
Remove a CPU/Memory Configuration
Obtaining the EM Exadata Plug-in
Confirm System Requirements
Known Issues With the EM Exadata Plug-in
Configuring the Exalogic Software
Exalogic Software Overview
Prepare to Configure the Exalogic Software
Enable Domain-Level Enhancements
Enable Cluster-Level Session Replication Enhancements
Configuring Grid Link Data Source for Dept1_Cluster1
Fast Connection Failover
Runtime Connection Load Balancing
XA Affinity
SCAN Addresses
Secure Communication With Oracle Wallet
Create a Grid Link Data Source on Dept1_Cluster1
Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1
Configure the Database to Support IB
Enable SDP Support for JDBC
Monitor SDP Sockets
Create an SDP Listener on the IB Network
Administering Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Create a Boot Environment
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Create a Snapshot of a Boot Environment
Remove Unwanted Boot Environments
Administering DISM
DISM Restrictions
Disable DISM
Administering Storage Servers
Monitor Write-through Caching Mode
Shut Down or Reboot a Storage Server
Drop a Storage Server
Glossary
Index
Create a grid link data source for each of the Oracle database instances during the process of setting up the multidata source, both for these data sources and the global leasing multidata source.
  1. Prepare to create the data source.
    1. Ensure that this is a non-xa data source.
    2. Target these data sources to the Dept1_Cluster1 cluster.
    3. Set the data sources connection pool initial capacity to 0.
      1. In the Oracle WebLogic Server Administration Console, select Services, JDBC, and then Datasources.
      2. In the Datasources screen, click the Datasource Name, then click the Connection Pool tab, and enter 0 in the Initial capacity field.
    4. Ensure that an ONS daemon is running on your database servers at all times. Start the ONS daemon on a database server by running the onsctl command:
      start
  2. Log in to the Oracle WebLogic Server Administration Console.
  3. If you have not already done so, in the Change Center of the Administration Console, click Lock & Edit.
  4. In the Domain Structure tree, expand Services, then select Data Sources.
  5. On the Summary of Data Sources page, click New and select GridLink Data Source.
    The Create a New JDBC GridLink Data Source page is displayed.
  6. Enter the following information, then click Next.
    • Logical name for the datasource in the Name field. For example, gridlink.
    • Name for JNDI. For example, jdbc/gridlink.
  7. In the Transaction Options page, deselect Supports Global Transactions, and click Next.
  8. Select Enter individual listener information and click Next.
  9. Enter the following connection properties:
    • Service Name: Enter the name of the RAC service in the Service Name field. For example, enter myService in Service Name.
      Note - The Oracle RAC Service name is defined on the database, and it is not a fixed name.
    • Host Name: Enter the DNS name or IP address of the server that hosts the database. For an Oracle GridLink service-instance connection, this must be the same for each data source in a given multi data source.
    • Port: Enter the port on which the database server listens for connections requests.
    • Database User Name: Enter the database user name. For example, myDataBase.
    • Password: Enter the password. For example, myPassword1.
      Confirm password and click Next.
    Tip - For more information, refer to the Oracle Fusion Middleware Oracle WebLogic Server Administration Console Online Help.
    The console automatically generates the complete JDBC URL. For example:
    jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=left)(PORT=1234))(ADDRESS=(PROTOCOL=TCP)(HOST=right)(PORT=1234))(ADDRESS=(PROTOCOL=TCP)(HOST=center)(PORT=1234)))(CONNECT_DATA=(SERVICE_NAME=myService)))
  10. On the Test GridLink Database Connection page, review the connection parameters and click Test All Listeners.
    Oracle WebLogic attempts to create a connection from the administration server to the database. Results from the connection test are displayed at the top of the page. If the test is unsuccessful, you should correct any configuration errors and retry the test.
    Click Next.
  11. In the ONS Client Configuration page, do the following:
    1. Select Fan Enabled to subscribe to and process FAN events.
    2. In the ONS host and port fields, enter a comma-separated list of ONS daemon listen addresses and ports for receiving ONS-based FAN events.
      You can use SCAN addresses to access FAN notifications.
    3. Click Next.
  12. On the Test ONS Client Configuration page, review the connection parameters and click Test All ONS Nodes.
    Click Next.
  13. In the Select Targets page, select Dept1_Cluster1 as the target and All Servers in the cluster.
  14. Click Finish.
  15. Click Activate Changes.
  16. Configure SDP-enabled JDBC drivers for the cluster.
    For instructions, see Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1.
