Skip Navigation Links
Exit Print View
Oracle SuperCluster M6-32
Owner's Guide: Administration
search filter icon
search icon
Document Information
Using This Documentation
Product Documentation Library
Feedback
Understanding SuperCluster Software
Identify the Version of SuperCluster Software
SuperCluster Tools
Controlling SuperCluster M6-32
Cautions
Power On SuperCluster M6-32
Powering Off SuperCluster M6-32 Gracefully
Shut Down the Oracle Solaris Cluster
Shut Down the Enterprise Controller (Ops Center)
Shut Down the Database
Shut Down the Storage Servers
Power Off the Storage Servers
Shut Down the LDoms
Shut Down the OS on the Compute Servers
Shut Down the ZFS Storage Appliance
Power Off the Switches and Racks
Power Off SuperCluster M6-32 in an Emergency
Monitoring SuperCluster M6-32 (OCM)
OCM Overview
Access OCM Documentation
Monitoring the System With ASR
ASR Overview
ASR Resources
ASR Installation Overview
Configure ASR on the Compute Servers (Oracle ILOM)
Configure SNMP Trap Destinations for Storage Servers
Configure ASR on the ZFS Storage Appliance
Configuring ASR on the Compute Servers (Oracle Solaris 11)
Enable the HTTP Receiver on the ASR Manager
Enable HTTPS on ASR Manager (Optional)
Register Compute Servers With Oracle Solaris 11 or Database Domains to ASR Manager
Approve and Verify ASR Asset Activation
Tuning SuperCluster M6-32
ssctuner Overview
Monitor ssctuner Activity
View Log Files
Change ssctuner Properties and Disable Features
Install ssctuner
Enable ssctuner
Configuring CPU and Memory Resources (osc-setcoremem)
osc-setcoremem Overview
Minimum and Maximum Resources (Dedicated Domains)
Supported Domain Configurations
Plan CPU and Memory Allocations
Display the Current Domain Configuration (osc-setcoremem)
Display the Current Domain Configuration (ldm)
Change CPU/Memory Allocations (Socket Granularity)
Change CPU/Memory Allocations (Core Granularity)
Park Cores and Memory
Access osc-setcoremem Log Files
View the SP Configuration
Revert to a Previous CPU/Memory Configuration
Remove a CPU/Memory Configuration
Obtaining the EM Exadata Plug-in
Confirm System Requirements
Known Issues With the EM Exadata Plug-in
Configuring the Exalogic Software
Exalogic Software Overview
Prepare to Configure the Exalogic Software
Enable Domain-Level Enhancements
Enable Cluster-Level Session Replication Enhancements
Configuring Grid Link Data Source for Dept1_Cluster1
Fast Connection Failover
Runtime Connection Load Balancing
XA Affinity
SCAN Addresses
Secure Communication With Oracle Wallet
Create a Grid Link Data Source on Dept1_Cluster1
Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1
Configure the Database to Support IB
Enable SDP Support for JDBC
Monitor SDP Sockets
Create an SDP Listener on the IB Network
Administering Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Create a Boot Environment
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Create a Snapshot of a Boot Environment
Remove Unwanted Boot Environments
Administering DISM
DISM Restrictions
Disable DISM
Administering Storage Servers
Monitor Write-through Caching Mode
Shut Down or Reboot a Storage Server
Drop a Storage Server
Glossary
Index
Oracle RAC 11g Release 2 supports client connections across multiple networks. This release also provides load balancing and failover of client connections within the network that they are connecting. To add a listener for the EECS connections coming in on the IB network, first add a network resource for the IB network with Virtual IP addresses.
Note - This example lists two Database Domains. If you have more than two Database Domains in your SuperCluster M6-32, you must repeat Database Domain-specific lines for each Database Domain in the cluster.
  1. Edit the /etc/hosts file on each Database Domain in the cluster to add the virtual IP addresses you will use for the IB network.
    Ensure that these IP addresses are not used.
    The following is an example:
    # Added for Listener over IB
    192.168.10.21 ssc01db01-ibvip.mycompany.com ssc01db01-ibvip
    192.168.10.22 ssc01db02-ibvip.mycompany.com ssc01db02-ibvip
  2. On one of the Database Domains, as the root user, create a network resource for the IB network, as in the following example:
    # /u01/app/grid/product/11.2.0.2/bin/srvctl add network -k 2 -S 192.168.10.0/255.255.255.0/bondib0
  3. Validate that the network was added correctly, by running one of the following commands:
    # /u01/app/grid/product/11.2.0.2/bin/crsctl stat res -t | grep net
    ora.net1.network
    ora.net2.network -- Output indicating new Network resource
    or
    # /u01/app/grid/product/11.2.0.2/bin/srvctl config network -k 2
    Network exists: 2/192.168.10.0/255.255.255.0/bondib0, type static -- Output indicating Network resource on the 192.168.10.0 subnet
  4. Add the Virtual IP addresses on the network created in Step 2, for each node in the cluster.
    srvctl add vip -n ssc01db01 -A ssc01db01-ibvip/255.255.255.0/bondib0 -k 2
    srvctl add vip -n ssc01db02 -A ssc01db02-ibvip/255.255.255.0/bondib0 -k 2
  5. As the "oracle" user (who owns the grid infrastructure home), add a listener which listens on the VIP addresses created in Step 3.
    srvctl add listener -l LISTENER_IB -k 2 -p TCP:1522,/SDP:1522
  6. For each database that will accept connections from the middle tier, modify the listener_networks init parameter to allow load balancing and failover across multiple networks (Ethernet and IB).
    You can either enter the full tnsnames syntax in the initialization parameter or create entries in tnsnames.ora in the $ORACLE_HOME/network/admin directory. The tnsnames.ora entries must exist in the GRID_HOME.
    The following example first updates tnsnames.ora. Complete this step on each Database Domain in the cluster with the correct IP addresses for that Database Domain. LISTENER_IBREMOTE should list all other Database Domains that are in the cluster. DBM_IB should list all Database Domains in the cluster.
    Note - The TNSNAMES entry is only read by the database instance on startup. If you modify the entry that is referred to by any init.ora parameter (LISTENER_NETWORKS), you must restart the instance or issue an ALTER SYSTEM SET LISTENER_NETWORKS command for the modifications to take affect by the instance.
    (DESCRIPTION =
    DBM =
    (ADDRESS = (PROTOCOL = TCP)(HOST = ssc01-scan)(PORT = 1521))
    (CONNECT_DATA =
    (SERVER = DEDICATED)
    (SERVICE_NAME = dbm)
    DBM_IB =
    (DESCRIPTION =
    (LOAD_BALANCE=on)
    (ADDRESS = (PROTOCOL = TCP)(HOST = ssc01db01-ibvip)(PORT = 1522))
    (ADDRESS = (PROTOCOL = TCP)(HOST = ssc01db02-ibvip)(PORT = 1522))
    (CONNECT_DATA =
    LISTENER_IBREMOTE =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = TCP)(HOST = ssc01db02-ibvip.mycompany.com)(PORT = 1522))
    LISTENER_IBLOCAL =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = TCP)(HOST = ssc01db01-ibvip.mycompany.com)(PORT = 1522))
    (ADDRESS = (PROTOCOL = SDP)(HOST = ssc01db01-ibvip.mycompany.com)(PORT = 1522))
    LISTENER_IPLOCAL =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = TCP)(HOST = ssc0101-vip.mycompany.com)(PORT = 1521))
    LISTENER_IPREMOTE =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = TCP)(HOST = ssc01-scan.mycompany.com)(PORT = 1521))
  7. Modify the listener_networks init parameter.
    Connect to the database instance as sysdba.
    SQLPLUS> alter system set listener_networks='((NAME=network2) (LOCAL_LISTENER=LISTENER_IBLOCAL)(REMOTE_LISTENER=LISTENER_IBREMOTE))', '((NAME=network1)(LOCAL_LISTENER=LISTENER_IPLOCAL)(REMOTE_LISTENER=LISTENER_IPREMOTE))' scope=both;
  8. Stop and start LISTENER_IB for the modification in Step 7.
    srvctl stop listener -l LISTENER_IB
    srvctl start listener -l LISTENER_IB
