Skip Navigation Links
Exit Print View
Oracle SuperCluster M6-32
Owner's Guide: Administration
search filter icon
search icon
Document Information
Using This Documentation
Product Documentation Library
Feedback
Understanding SuperCluster Software
Identify the Version of SuperCluster Software
SuperCluster Tools
Controlling SuperCluster M6-32
Cautions
Power On SuperCluster M6-32
Powering Off SuperCluster M6-32 Gracefully
Shut Down the Oracle Solaris Cluster
Shut Down the Enterprise Controller (Ops Center)
Shut Down the Database
Shut Down the Storage Servers
Power Off the Storage Servers
Shut Down the LDoms
Shut Down the OS on the Compute Servers
Shut Down the ZFS Storage Appliance
Power Off the Switches and Racks
Power Off SuperCluster M6-32 in an Emergency
Monitoring SuperCluster M6-32 (OCM)
OCM Overview
Access OCM Documentation
Monitoring the System With ASR
ASR Overview
ASR Resources
ASR Installation Overview
Configure ASR on the Compute Servers (Oracle ILOM)
Configure SNMP Trap Destinations for Storage Servers
Configure ASR on the ZFS Storage Appliance
Configuring ASR on the Compute Servers (Oracle Solaris 11)
Enable the HTTP Receiver on the ASR Manager
Enable HTTPS on ASR Manager (Optional)
Register Compute Servers With Oracle Solaris 11 or Database Domains to ASR Manager
Approve and Verify ASR Asset Activation
Tuning SuperCluster M6-32
ssctuner Overview
Monitor ssctuner Activity
View Log Files
Change ssctuner Properties and Disable Features
Install ssctuner
Enable ssctuner
Configuring CPU and Memory Resources (osc-setcoremem)
osc-setcoremem Overview
Minimum and Maximum Resources (Dedicated Domains)
Supported Domain Configurations
Plan CPU and Memory Allocations
Display the Current Domain Configuration (osc-setcoremem)
Display the Current Domain Configuration (ldm)
Change CPU/Memory Allocations (Socket Granularity)
Change CPU/Memory Allocations (Core Granularity)
Park Cores and Memory
Access osc-setcoremem Log Files
View the SP Configuration
Revert to a Previous CPU/Memory Configuration
Remove a CPU/Memory Configuration
Obtaining the EM Exadata Plug-in
Confirm System Requirements
Known Issues With the EM Exadata Plug-in
Configuring the Exalogic Software
Exalogic Software Overview
Prepare to Configure the Exalogic Software
Enable Domain-Level Enhancements
Enable Cluster-Level Session Replication Enhancements
Configuring Grid Link Data Source for Dept1_Cluster1
Fast Connection Failover
Runtime Connection Load Balancing
XA Affinity
SCAN Addresses
Secure Communication With Oracle Wallet
Create a Grid Link Data Source on Dept1_Cluster1
Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1
Configure the Database to Support IB
Enable SDP Support for JDBC
Monitor SDP Sockets
Create an SDP Listener on the IB Network
Administering Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Create a Boot Environment
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Create a Snapshot of a Boot Environment
Remove Unwanted Boot Environments
Administering DISM
DISM Restrictions
Disable DISM
Administering Storage Servers
Monitor Write-through Caching Mode
Shut Down or Reboot a Storage Server
Drop a Storage Server
Glossary
Index
Use this procedure to register compute servers with Oracle Solaris 11 or Database Domains to the ASR Manager.
  1. Log in to the compute server as superuser.
  2. Confirm that the asr-notify service is working:
    # svcs asr-notify
    • If you see this message:
      svcs: Pattern ‘asr-notify' doesn't match any instances
      then confirm that the asr-notify service is installed:
      # pkg list asr-notify
      pkg list: no packages matching ‘asr-modify' installed
      then install the asr-notify service:
      # pkg install system/fault-management/asr-notify
      Enter the svcs asr-notify command again to confirm that the asr-notify service is working.
      # svcs asr-notify
      STATE     STIME       FMRI
      online    16:06:05    svc:/system/fm/asr-notify:default
      then the asr-notify service is installed and is working properly
  3. Register the ASR manager using this command:
    # asradm register -e http://asr-manager-host:port-number/asr
    Example:
    # asradm register -e http://asrmanager1.mycompany.com:8777/asr
    Screens are displayed asking for your Oracle Support account name and password. After entering your Oracle Support account name and password, a notification is displayed, indicating that your registration is complete:
    Enter Orcle SSO User Name:
    Enter password:
    Registration complete.
  4. Run this command:
    # asradm list
    Example output:
    PROPERTY VALUE
    Status Successfully Registered with ASR manager
    System Id system-identification-number
    Asset Id asset-identification-number
    User username
    Endpoint URL http://asr-manager-host:port-number/asr
    The registration of the ASR Manager is complete.
  5. Repeat these instructions for all compute servers with Oracle Solaris 11 or Database Domains in your SuperCluster system.
  6. When you have completed the configuration of all the SuperCluster assets, approve and verify contacts in MOS.
    See Approve and Verify ASR Asset Activation for those instructions.
