Skip Navigation Links
Exit Print View
Oracle SuperCluster M6-32
Owner's Guide: Administration
search filter icon
search icon
Document Information
Using This Documentation
Product Documentation Library
Feedback
Understanding SuperCluster Software
Identify the Version of SuperCluster Software
SuperCluster Tools
Controlling SuperCluster M6-32
Cautions
Power On SuperCluster M6-32
Powering Off SuperCluster M6-32 Gracefully
Shut Down the Oracle Solaris Cluster
Shut Down the Enterprise Controller (Ops Center)
Shut Down the Database
Shut Down the Storage Servers
Power Off the Storage Servers
Shut Down the LDoms
Shut Down the OS on the Compute Servers
Shut Down the ZFS Storage Appliance
Power Off the Switches and Racks
Power Off SuperCluster M6-32 in an Emergency
Monitoring SuperCluster M6-32 (OCM)
OCM Overview
Access OCM Documentation
Monitoring the System With ASR
ASR Overview
ASR Resources
ASR Installation Overview
Configure ASR on the Compute Servers (Oracle ILOM)
Configure SNMP Trap Destinations for Storage Servers
Configure ASR on the ZFS Storage Appliance
Configuring ASR on the Compute Servers (Oracle Solaris 11)
Enable the HTTP Receiver on the ASR Manager
Enable HTTPS on ASR Manager (Optional)
Register Compute Servers With Oracle Solaris 11 or Database Domains to ASR Manager
Approve and Verify ASR Asset Activation
Tuning SuperCluster M6-32
ssctuner Overview
Monitor ssctuner Activity
View Log Files
Change ssctuner Properties and Disable Features
Install ssctuner
Enable ssctuner
Configuring CPU and Memory Resources (osc-setcoremem)
osc-setcoremem Overview
Minimum and Maximum Resources (Dedicated Domains)
Supported Domain Configurations
Plan CPU and Memory Allocations
Display the Current Domain Configuration (osc-setcoremem)
Display the Current Domain Configuration (ldm)
Change CPU/Memory Allocations (Socket Granularity)
Change CPU/Memory Allocations (Core Granularity)
Park Cores and Memory
Access osc-setcoremem Log Files
View the SP Configuration
Revert to a Previous CPU/Memory Configuration
Remove a CPU/Memory Configuration
Obtaining the EM Exadata Plug-in
Confirm System Requirements
Known Issues With the EM Exadata Plug-in
Configuring the Exalogic Software
Exalogic Software Overview
Prepare to Configure the Exalogic Software
Enable Domain-Level Enhancements
Enable Cluster-Level Session Replication Enhancements
Configuring Grid Link Data Source for Dept1_Cluster1
Fast Connection Failover
Runtime Connection Load Balancing
XA Affinity
SCAN Addresses
Secure Communication With Oracle Wallet
Create a Grid Link Data Source on Dept1_Cluster1
Configuring SDP-Enabled JDBC Drivers for Dept1_Cluster1
Configure the Database to Support IB
Enable SDP Support for JDBC
Monitor SDP Sockets
Create an SDP Listener on the IB Network
Administering Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Create a Boot Environment
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Create a Snapshot of a Boot Environment
Remove Unwanted Boot Environments
Administering DISM
DISM Restrictions
Disable DISM
Administering Storage Servers
Monitor Write-through Caching Mode
Shut Down or Reboot a Storage Server
Drop a Storage Server
Glossary
Index
The disk controller on each storage server periodically performs a discharge and charge of the controller battery. During the operation, the write cache policy changes from write-back caching to write-through caching. Write-through cache mode is slower than write-back cache mode. However, write-back cache mode has a risk of data loss if the storage server loses power or fails. For storage server releases earlier than release 11.2.1.3, the operation occurs every month. For Oracle Exadata Storage Server Software release 11.2.1.3 and later, the operation occurs every three months, for example, at 01:00 on the 17th day of January, April, July, and October.
  1. Change the start time for when the learn cycle occurs, by typing a command similar to the following.
    CellCLI> ALTER CELL bbuLearnCycleTime="2011-01-22T02:00:00-08:00"
    The time reverts to the default learn cycle time after the cycle completes.
  2. View the time for the next learn cycle.
    CellCLI> LIST CELL ATTRIBUTES bbuLearnCycleTime
    The storage server generates an informational alert about the status of the caching mode for logical drives on the cell, for example:
    HDD disk controller battery on disk controller at adapter 0 is going into a learn cycle. This is a normal maintenance activity that occurs quarterly and runs for approximately 1 to 12 hours. The disk controller cache might go into WriteThrough caching mode during the learn cycle. Disk write throughput might be temporarily lower during this time. The message is informational only, no action is required.
  3. View the status of the battery.
    # /opt/MegaRAID/MegaCli/MegaCli64 -AdpBbuCmd -GetBbuStatus -a0
    The following is example output.
    BBU status for Adapter: 0
    BatteryType: iBBU08
    Voltage: 3721 mV
    Current: 541 mA
    Temperature: 43 C
    BBU Firmware Status:
    Charging Status : Charging
    Voltage : OK
    Temperature : OK
    Learn Cycle Requested : No
    Learn Cycle Active : No
    Learn Cycle Status : OK
    Learn Cycle Timeout : No
    I2c Errors Detected : No
    Battery Pack Missing : No
    Battery Replacement required : No
    Remaining Capacity Low : Yes
    Periodic Learn Required : No
    Transparent Learn : No
    Battery state:
    GasGuageStatus:
    Fully Discharged : No
    Fully Charged : No
    Discharging : No
    Initialized : No
    Remaining Time Alarm : Yes
    Remaining Capacity Alarm: No
    Discharge Terminated : No
    Over Temperature : No
    Charging Terminated : No
    Over Charged : No
    Relative State of Charge: 7 %
    Charger System State: 1
    Charger System Ctrl: 0
    Charging current: 541 mA
    Absolute State of Charge: 0%
    Max Error: 0 %
    Exit Code: 0x00
