Environmental
Specifications
The Oracle Flash Accelerator F160 PCIe Card operates and is stored in an environment defined
by the parameters and specifications in the following table:
Operating temperature
0 to 55° C with specified airflow
Non-operating temperature
Storage and transit environment: –55° C to 95° C (dry bulb)
Temperature monitoring
Dry bulb temperature
Maximum dry bulb temperature shall be derated by 3.3° C per 1000 m above 500 m
Altitude (Simulated)
Operating: -1,000 to 10,000 ft
Non-Operating: -1,000 to 40,000 ft
Relative humidity range
Operational environment: 8% to 80% noncondensing
Storage and transit environment: 5% to 95% noncondensing
Non-operating: -20° C to 75° C noncondensing
Thermal sensors
Airflow requirement
More than 300 LFM (linear feet/minute) at 55° C with airflow
towards IO bracket
Note -
For specific site planning guidelines and best practices, refer to the server documentation
and product notes for your server. Refer to the system site planning guide, if available.
