Go to main content
SPARC T7 Series Servers Administration Guide
Exit Print View
Updated: August 2017
Power On a Server With Multiple Active Domains (Oracle VM Server for SPARC)
If the server is configured with multiple Oracle VM Server for SPARC domains, use this procedure to power on the server and restart the domains.
  1. Log in to Oracle ILOM.
    See Log In to Oracle ILOM.
  2. Power on the host.
    -> start /System
    Are you sure you want to start /System (y/n) ? y
    Starting /System
    -> start /HOST/console
    Are you sure you want to start /HOST/console (y/n)? y
  3. Log in to Oracle Solaris as a user with root privileges.
  4. Start all of the nonprimary domains.
    Starting a domain automatically binds the domain.
    # ldm start-domain domain-name
  5. Boot all of the nonprimary domains.
    The method you use to access a domain depends on how you have configured the consoles for your domains.
    Boot each domain the same way you boot a server. See Boot the OS (Oracle ILOM).
Related Information
