Go to main content
SPARC T7 Series Servers Administration Guide
Exit Print View
Updated: August 2017
OpenBoot Configuration Parameters
Parameter
Default Value
Description
auto-boot-on-error?
false
Controls whether or not the host attempts to boot after POST detects a nonrecoverable error.
  • false – Host does not attempt to boot and stops at the ok prompt.
  • true – Host automatically attempts to boot.
auto-boot?
true
Controls whether or not the host automatically boots after a system reset or when the power is turned on.
  • true – Host automatically attempts to boot from the devices specified in boot-device.
boot-command
boot
Specifies the command to be executed when auto-boot? is true. Valid boot commands:
  • boot – Boots kernel from devices specified in boot-device.
  • boot net – Boots kernel from the network.
  • boot cdrom – Boots kernel from the CD-ROM.
  • boot disk1:h – Boots from disk 1 partition h.
  • boot tape – Boots default file from tape.
  • boot device-path – Boots from the device specified as device-path. See Locate Device Paths (OpenBoot).
boot-device
disk net
Contains the name of the default boot device that is used when OpenBoot is not in diagnostic mode.
boot-file
An optional parameter that provides boot arguments that are used when OpenBoot is not in diagnostic mode.
diag-switch?
false
If the value is true, runs in the Diagnostic mode.
network-boot-arguments
An optional parameter that enables you to set configuration parameters to be used by OpenBoot when you perform a WAN boot. Setting this parameter takes precedence over any default boot parameter values. Refer to the eeprom(1M) man page for details.
Related Information
