Power On the Server (Oracle
ILOM CLI)
Note - By default, the host automatically attempts
to boot when the host is reset or powered on. To learn about the
parameters that control this action, see
Configuring Boot Parameters.
- Log
in to Oracle ILOM.
See Log In to Oracle ILOM.
- At the Oracle ILOM prompt, type:
-> start /System
Are you sure you want to start /System (y/n) ? y
Starting /System
Note - To skip being prompted for confirmation, use the start -script /System command.
- Start the host console to view host output.
-> start /HOST/console
Are you sure you want to start /HOST/console (y/n)? y
