Go to main content
oracle home
SPARC T7-2 Server Installation Guide
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
SPARC T7-2 Server Documentation Library
Updated: July 2017
Document Information
Using This Documentation
Product Documentation Library
Feedback
Understanding the Server
Installation Task Overview
Server Overview
Front Panel Components (Installation)
Rear Panel Components (Installation)
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Airflow Precautions
Preparing for Installation
Shipping Kit
Handling Precautions
ESD Precautions
Tools Needed for Installation
Installing the Server
Optional Components
Rack Compatibility
Rack Cautions
Stabilize the Rack
Disassemble Slide Rails
Install the Rackmount Hardware
Attach Slide Rail Assemblies to the Rack
Install the Server
Install the CMA
Verify Operation of Slide Rails and CMA
Connecting the Server Cables
Cabling Requirements
Identifying Ports
USB Ports
SER MGT Port
RJ-45 Crossover Pinouts
NET MGT Port
Gigabit Ethernet Ports
VGA Port
Connecting Data and Management Cables
Connect the SER MGT Cable
Connect the NET MGT Cable
Connect Ethernet Network Cables
Connect Other Data Cables
Secure Cables to the CMA
Powering On the Server for the First Time
Prepare the Power Cords
Connect a Terminal or Emulator to the SER MGT Port
Power on the Server for the First Time
Oracle ILOM System Console
Installing the OS
Configure the Preinstalled OS
Reach a State to Install a Fresh OS (Oracle ILOM CLI)
Reach a State to Install a Fresh OS (Oracle ILOM Web Interface)
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the SP
Log In to the SP (SER MGT Port)
Assign a Static IP Address to the NET MGT Port
Glossary
Index
Index A
Index B
Index C
Index D
Index E
Index F
Index G
Index H
Index I
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Index V
Index W
Language:
English
July 2017
Describes how to install and power on the SPARC T7-2 server from Oracle
Feedback
Server Overview
Airflow Precautions
Shipping Kit
ESD Precautions
Optional Components
Rack Compatibility
Rack Cautions
Stabilize the Rack
Install the Server
Install the CMA
Identifying Ports
USB Ports
SER MGT Port
NET MGT Port
VGA Port
Installing the OS
Glossary
Index
A
B
C
D
E
F
G
H
I
L
M
N
O
P
R
S
T
U
V
W
