Install the Rackmount Hardware
This procedure describes how to attach the mounting
brackets to the server so you can rackmount the server.
- Position
a mounting bracket against the chassis so that the slide rail lock
is at the server front, and the five keyhole openings on the mounting
bracket are aligned with the five locating pins on the side of the
chassis.
Note - The mounting brackets are identical and can be installed
on either side of the chassis.
- With the heads of the five chassis
locating pins protruding though the five keyhole openings in the
mounting bracket, pull the mounting bracket toward the front of
the chassis until the mounting bracket clip locks into place with
an audible click.
- Verify that the rear locating
pin has engaged the mounting bracket clip.
- Repeat to install the remaining
mounting bracket on the other side of the server.
