Oracle Quad 10Gb Ethernet Adapter User's Guide
Exit Print View
Updated: July 2015
Configure VLANs (Windows)
  1. Click Control Panel.
  2. Click Network Connection.
  3. Click the folder icon from the sub-manual bar.
  4. Right-click the Oracle Quad 10Gb Ethernet Adapter port, then select Properties.
  5. Click Configure.
  6. Click VLAN, then click New.
  7. Type VLAN with ID (for example, type VLAN10).
  8. Click OK.
  9. Open the Local Connections for VLAN window from the Network Connections window (Control Panel -> Network Internet -> Network Connections).
  10. Right-click the Properties button, and select the TCP/IPv4 port in the list.
  11. Click the Properties button, and fill in the desired IP address.
  12. Click Subnet Mask.
    The value 255.255.255.0 is displayed.
  13. Click OK.
  14. Repeat Step 3 through Step 10 until all the network ports are VLAN configured.
    Note - Ensure that the firewall is configured to allow VLAN traffic. Otherwise, the VLAN might not operate properly.
Related Information
