If the driver is installed correctly, the Ethernet adapter interfaces labeled as "Intel(R) I450 10-Gigabit Dual Port Network Connection” will be displayed at the Network Connection screen.
The minimum Windows Server 2008 driver version is i40ea62.
The minimum Windows Server 2012 driver version is i40ea63.
The minimum Windows Server 2012 R2 driver version is i40ea64.
