ok show-nets a) /niu@480/network@0 b) /pci@400/pci@2/pci@0/pci@c/network@0,3 c) /pci@400/pci@2/pci@0/pci@c/network@0,2 d) /pci@400/pci@2/pci@0/pci@c/network@0,1 e) /pci@400/pci@2/pci@0/pci@c/network@0 f) /pci@400/pci@2/pci@0/pci@a/network@0,1 g) /pci@400/pci@2/pci@0/pci@a/network@0 q) NO SELECTION Enter Selection, q to quit: q
These examples assume that /pci@400/pci@2/pci@0/pci@c/network@0 is a port on the adapter.
ok cd /pci@400/pci@2/pci@0/pci@c/network@0
ok .properties
The output should be similar to this:
vf-assigned-addresses c3060000 00000041 10810000 00000000 00010000 c3060003 00000041 10a10000 00000000 00004000 assigned-addresses c3060010 00000041 10000000 00000000 00800000 c306001c 00000041 10800000 00000000 00008000 82060030 00000000 00100000 00000000 00080000 vf-reg 43060000 00000000 00000000 00000000 00010000 43090003 00000000 00000000 00000000 00004000 reg 00060000 00000000 00000000 00000000 00000000 43060010 00000000 00000000 00000000 00800000 4306001c 00000000 00000000 00000000 00008000 02060030 00000000 00000000 00000000 00080000 local-mac-address 68 05 ca 2b 93 08 phy-type xgf version Oracle Quad 10Gb Ethernet Adapter FCode 2.12 7/16/2015 board-model 7096437 model 7111185/7111186 compatible pciex8086,1583.108e.7blb.1 pciex8086,1583.108e.7blb pciex8086,1583.1 pciex8086,1583 pciexclass,020000 pciexclass,0200 address-bits 00000030 max-frame-size 00002400 network-interface-type ethernet device_type network name network fcode-rom-offset 00054000 vf-stride 00000001 first-vf-ofset 00000010 total-vfs 00000020 initial-vfs 00000020 #vfs 00000020 port-type PCIE-Endpoint interrupts 00000001 cache-line-size 00000010 class-code 00020000 subsystem-id 00007b1b subsystem-vendor-id 0000108e revision-id 00000001 device-id 00001583 vendor-id 00008086
If you do not see the device listed, check that the adapter is properly seated. If necessary, reinstall the adapter.
ok device-end
