# modinfo|grep i40e 173 7b762000 17998 100 1 i40e (Intel 10Gb Ethernet 1.0.6)
If the version number is not at least 1.0.6, you must install the latest driver patch.
For the latest list of supported platforms and operating systems, refer to the Oracle Quad 10Gb Ethernet Adapter Product Notes at:
http://www.oracle.com/goto/quad-10gb-ethernet-adapter/docs. For Oracle Solaris OS systems, the minimum supported version is required, which is Oracle Solaris 11.2 SRU11.
# grep i40e /etc/path_to_inst
If the adapter is properly installed, you should see output similar to this:
“/pci@0,0/pci8086,3c0a@3,2/pci108e,7b15@0” 0 “ixgbe” “/pci@0,0/pci8086,3c0a@3,2/pci108e,7b15@0,1” 1 “ixgbe”
