The PIMv6 component corresponds to each instance of a PIMv6 domain. The component is classified as being in the sparse mode. Dense mode is not supported in the 1.2 release.
SEFOS# configure terminal SEFOS(config-if)# set ipv6 pim enable
SEFOS(config)# ip pim component component_ID SEFOS(pim-comp)# end
SEFOS# show ipv6 pim component 2 PIM Component Information --------------------------- Component-Id: 2 PIM Mode: sparse, PIM Version: 2 Elected BSR: :: Candidate RP Holdtime: 0
