An RP-candidate router is a router that is configured to send periodic RP-candidate advertisement messages to the BSR. This router also processes join or prune messages or registers messages for the advertised group prefix when it is elected as an RP. When you configure the RP-candidate address, you set the address of the interface that is advertised as an RP-candidate.
SEFOS(config)# interface vlan 7 SEFOS(config-if)# ipv6 pim componentId 1 SEFOS(config-if)# exit
SEFOS(config)# ip pim component 1
SEFOS(pim-comp)# rp-candidate holdtime 30
SEFOS(pim-comp)# ipv6 pim rp-candidate rp-address ff02::e001:0 128 7777::11 SEFOS(pim-comp)# end
SEFOS# show ipv6 pim rp-candidate
CompId GroupAddress/PrefixLength RPAddress/Priority
1 ff02::e001:1/128 7777::11/4
SEFOS# show ipv6 pim rp-candidate 1
