To handle MLDv1 report packets, you must enable MLD over the interfaces.
SEFOS# conf t SEFOS(config)# int vlan 7 SEFOS(config-if)# ipv6 mld router SEFOS(config-if)# end
SEFOS(config)# interface vlan 2 SEFOS(config-if)# ipv6 pim componentId 1 SEFOS(config-if)# exit
SEFOS(config)# interface vlan 7 SEFOS(config-if)# ipv6 pim componentId 1 SEFOS(config-if)# end
SEFOS# configure terminal SEFOS(config)# interface vlan 7 SEFOS(config-if)# shutdown
SEFOS(config-if)# ipv6 pim bsr-candidate 20
SEFOS(config)# interface vlan 3 SEFOS(config-if)# ipv6 pim componentId 1 SEFOS(config-if)# exit
SEFOS(config)# ip pim component 1
SEFOS(pim-comp)# rp-candidate holdtime 30 SEFOS(pim-comp)# end
SEFOS(pim-comp)# ipv6 pim rp-candidate rp-address ff02::e001:0 128 7777::21 SEFOS(pim-comp)# end
SEFOS# show ipv6 pim mroute IP Multicast Routing Table -------------------------- Route Flags S: SPT Bit W: Wild Card Bit R: RPT Bit IIF State P: Pruned F: Forwarding A: Graft Ack Pending Timers: Uptime/Expires Interface State: Interface, State/Mode PIM Multicast Routing Table For Component 1 (2222::18,ff02::e001:0) ,00:00:21/ 05:32:29 , Incoming Interface : vlan2 ,RPF nbr : NULL ,Route Flags : S Outgoing InterfaceList : vlan7, Forwarding/Sparse ,00:00:10/05:32:29
SEFOS# show ipv6 pim mroute IP Multicast Routing Table -------------------------- Route Flags S: SPT Bit W: Wild Card Bit R: RPT Bit IIF State P: Pruned F: Forwarding A: Graft Ack Pending Timers: Uptime/Expires Interface State: Interface, State/Mode PIM Multicast Routing Table For Component 1 (2222::18,ff02::e001:0) ,00:17:31/ 05:10:59 , Incoming Interface : vlan7 ,RPF nbr : fe80::7777:11 ,Route Flags : S Outgoing InterfaceList : vlan3, Forwarding/Sparse ,00:17:31/--- (*, ff02::e001:0) ,00:17:36/ ---7777::21) Incoming Interface : vlan7 ,RPF nbr : NULL ,Route Flags : WR Outgoing InterfaceList : vlan3, Forwarding/Sparse ,00:17:36/---
