Static configuration allows additional structuring of the multicast traffic by directing the multicast join or prune messages to statically configured RPs.
SEFOS(config)# interface vlan 7 SEFOS(config-if)# ipv6 pim componentId 1 SEFOS(config-if)# end
SEFOS# configure terminal SEFOS(config)# set ip pim static-rp enable
SEFOS(config)# ip pim component 2
This step uses the following parameters:
RP address: 7777::11
Mask length: 128
Group address: ff02::e001:1
SEFOS(pim-comp)# ipv6 pim rp-static rp-address ff02::e001:1 128 7777::11 SEFOS(pim-comp)# end
SEFOS# show ipv6 pim rp-static 2 Static-RP Enabled CompId GroupAddress/PrefixLength RPAddress ------ ------------------------- --------- 2 ff02::e001:1/128 7777::11
