Access the BIOS Setup Utility menus.
See Access BIOS Setup Utility Menus.
In the BIOS Setup Utility menus, navigate to the IO Menu.
The IO Menu screen appears.
Select Add In Cards and press Enter to display the add-in card slots.
The Add In Cards screen appears.
Select the slot for which you want to configure the card, and press
Enter.
The IO resource allocation screen for that add-in card slot appears.
Do one of the following:
Select Enabled to enable I/O resource allocation for
the I/O card.
Select Disabled to disable I/O resource allocation for
the I/O card.
Press the F10 key to save the changes and exit the BIOS Setup Utility.
