Go to main content
Oracle® Exadata Storage Server X6-2 Extreme Flash Service Manual
Exit Print View
Updated: January 2018
Power On the Storage Server
As soon as the power cords are connected, standby power is applied. In standby power mode, the Power/OK LED on the storage server front panel blinks steadily. Depending on the configuration of the firmware, the system might boot. If it does not boot, follow this procedure.
  • Power on the storage server by performing one of the following actions:
    • Press the Power button on the front bezel.
    • Log in to the Oracle ILOM web interface, click Host Management → Power Control and select Power On from the Select Action list.
    • Log in to the Oracle ILOM command-line interface (CLI), and type the following command at the Oracle ILOM prompt:
      -> start /System
      When the storage server is powered on and the power-on self-test (POST) code checkpoint tests have completed, the green Power/OK status indicator (LED) on the front panel of the storage server lights and remains lit.
Related Information
