Identify the prerequisite and subsequent installation tasks that you must
perform in conjunction with this task.
See Installation Task Overview.
If the rack rear door is installed, open it.
Remove the module from its antistatic packaging.
Squeeze the top and bottom of the release lever, and move the release lever to
the fully open position.
Align the module to the slot where you are installing it.
The LEDs and data cable receptacles face you, and the release lever is to the
lower right.
Slide the module into the chassis until the release lever begins to
rise.
When the module is almost completely seated in the slot and the release lever
begins to rise, press down slightly on the top of the module to ensure that the
notch at the end of the release lever catches onto the groove in the slot
entrance in order to secure the module.
Note -
Ensure the handle appears in the fully locked position as in the
illustration when fully engaged.
Verify that the green OK LED lights.
Repeat Step 3 to
Step 8 to install the remaining modules.
Connect the data cables to the module.
See Connect Cables and Transceivers.
