Identify the prerequisite and subsequent installation tasks that you must
perform in conjunction with this task.
See Installation Task Overview.
Attach the cable to the appropriate connector of the node or host.
Route and bundle the data cables through the physical topology.
Bring the cable to the location in the rack where the module is
installed.
Orient the transceiver squarely and horizontally with the selected SFP+ port,
then carefully insert the transceiver into the port on the module until you feel
a detent or click..
Ensure the metal clip on the transceiver is in the closed position.
Remove the protective cap (if present) from the receptacle on the
transceiver and the connector of the cable, and visually inspect the cable
connector.
Orient the cable connector to the receptacle squarely and horizontally.
Note -
Ensure the metal clip on the transceiver is in the closed position prior
to connecting the cable to the transceiver.
Slowly move the connector in, and continue to push the connector in
until you feel a click.
Repeat Step 2 to Step 8 for any other cables and transceivers to be connected.
If the rack rear door is installed, close and secure it.
Verify the module installation.
See Verify Module Installation.
