Go to main content
SPARC T8-2 Server Installation Guide
Exit Print View
Updated: June 2019
Install the Rackmount Hardware
This procedure describes how to attach the mounting brackets to the server so you can rackmount the server.
  1. Position a mounting bracket against the chassis so that the slide rail lock is at the server front, and the five keyhole openings on the mounting bracket are aligned with the five locating pins on the side of the chassis.
    Note - The mounting brackets are identical and can be installed on either side of the chassis.
    image:Graphic of mounting bracket aligned with server chassis locating pins.
  2. With the heads of the five chassis locating pins protruding though the five keyhole openings in the mounting bracket, pull the mounting bracket toward the front of the chassis until the mounting bracket clip locks into place with an audible click.
  3. Verify that the rear locating pin has engaged the mounting bracket clip.
  4. Repeat to install the remaining mounting bracket on the other side of the server.
Related Information
