NET MGT
Port
The NET MGT RJ-45 port, located on the rear panel, provides an optional Ethernet connection to
the SP. The NET MGT port is an optional connection to Oracle ILOM on the SP. The SP
NET MGT port uses an RJ-45 cable for a 1000BASE-T connection (auto-negotiates to 10
Mb/sec, 100 Mb /sec, and 1 Gb/sec, full-duplex only). If your network does not use a
DHCP server, this port will not be available until you configure network settings
through the SER MGT port.
1 |
Transmit Data + |
5 |
No Connect |
2 |
Transmit Data – |
6 |
Receive Data – |
3 |
Receive Data + |
7 |
No Connect |
4 |
No Connect |
8 |
No Connect |
