Go to main content
SPARC T8-2 Server Installation Guide
Exit Print View
Updated: June 2019
Rack Compatibility
Check that your rack is compatible with the slide rail and cable management assembly options. The optional slide rails are compatible with a wide range of equipment racks that meet the following standards.
Item
Requirement
Structure
Four-post rack (mounting at both front and rear). Two-post racks are not compatible.
Rack horizontal opening and unit vertical pitch
Conforms to ANSI/EIA 310-D-1992 or IEC 60927 standards.
Rack rail mounting hole sizes
Only 9.5-mm square hole and M6 round mounting holes are supported. All other sizes, including 7.2-mm, M5, or 10-32 mounting holes, are not supported.
Distance between front and rear mounting planes
Minimum: 24.5 in. (622 mm)
Maximum: 35.25 in. (895 mm)
Clearance depth in front of front mounting plane
Distance to front cabinet door is at least 1.06 in. (27 mm).
Clearance depth behind front mounting plane
Distance to rear cabinet door is at least 35.5 in. (900 mm) with the CMA, or 30.4 in. (770 mm) without the cable management assembly.
Clearance width between front and rear mounting planes
Distance between structural supports and cable troughs is at least 18 in. (456 mm).
Server dimensions
Depth: 29.63 in. (752.5 mm)
Width: 17.185 in. (436.5 mm)
Height: 5.11 in. (129.8 mm)
Related Information
