Working with Return Authorizations: Streamlined Process
Purpose: If the Use Streamlined Return Authorizations (F44) system control value is selected, when you process return authorizations:
• When you select an order for returns processing, the screen displays each item on that order that is available for returns processing. Items are available for return if they have been shipped and a return has not yet been completely processed.
• Depending on your authority to create, receive, and credit return authorizations, returns are processed automatically as far as your authority extends. For example, you cannot specify that you want to "create only" if you also have authority to receive, or to receive and credit.
• You can review order line history while processing returns.
• You can work with additional charge codes while processing returns.
See Working with Return Authorizations: Standard Process for more information on how standard processing works.
Selecting an order: The process you use to select an order for return authorization processing is the same regardless of whether you use the standard or streamlined process. See Selecting Orders for Return (WRTA).
Authority level: Your authority level is determined by the following secured features:
• Enter Return Authorization (A28)
• Receive Return Authorization (A29)
• Credit Return Authorization (A34)
Additionally, the Delete Return Authorizations (B03) secured feature controls the ability to delete a return authorization that has been created, but not yet received.
Return authorization download triggers: If the Create Return Download Triggers (K28) system control value is selected, the system creates a return authorization download (RAD) trigger when you create, change, or delete a return authorization line, based on the trigger rules defined for the Return Authorization Download (RETURN_OUT) integration layer job. The RETURN_OUT integration layer job monitors for return authorization download triggers and generates a Return Authorization Outbound XML Message (CWReturnRAOut) to send the return authorization information to a remote system. See Outbound Return API for an overview.
Retail pickup or delivery orders: You can process a return against a retail pickup or delivery order; however, shipping the order deactivates the Order Broker Payment Type (K98) applied to these orders, so you would then need to enter a new payment method in order to process the related refund.
Note: You cannot process an exchange against a retail pickup or delivery order.
The system does not send a status update to the Order Broker when you process a return against a retail pickup or delivery order.
See Retail Pickup (including Ship-for-Pickup) or Delivery Orders for an overview.
Pick slip preparation: When you select an order for return authorization, the system removes any pick slip preparation from the order. When you accept or reject the return authorization, the system determines if the order qualifies for pick slip preparation and reapplies it to the order. If you add an exchange item to the order, the system performs pick slip preparation for the exchange item when you receive the return authorization. See Preparing Orders for Pick Slip Generation.
In this topic:
• Work with Returns for Order Screen
• Return/Exchange Item Screen (Creating a Return)
• Return/Exchange Item Screen (Create/Return All)
• Change RA Detail Screen (Complete/Process a Return for an Item)
• Work with RA Detail for Item Screen
Use this screen to create and process return authorizations as far as your authority extends. From this screen, you can also display a return authorization in process, review order line history, advance to standard order inquiry, or work with additional charges.
This screen displays each item on the order eligible for a return (that is, all shipped items that have not yet had returns fully processed).
Note: The Edit Customer Actions Window may appear before this screen.
How to display this screen: Select an order through the Work with Return Authorizations scan screens; see Selecting Orders for Return (WRTA).
See messages: The text SEE MSGS appears in the upper right corner of the screen if:
• the Display Customer Action Notes/Messages in RA (F64) system control value is selected, and,
• there are any order messages for the order you selected.
You can select Order Inquiry to advance to standard order inquiry and select Messages to display the Work with Order Messages Screen.
Field |
Description |
Order number |
A number to identify an order. Numeric, 7 positions; display-only, assigned by the system. |
Ship-to number (Unlabeled field to the right of the order number) |
A number that identifies the shipping address on an order; separated from the order number by a hyphen. Numeric, 3 positions; display-only, assigned by the system. |
Customer # |
This number identifies the customer who placed the order. Numeric, 9 positions; display-only; assigned by the system. |
Customer name (Unlabeled field to the right of the customer number) |
The name of the customer. Alphanumeric, 41 positions; display-only. |
Ln# (Line number) |
The number of the order line containing the item eligible for return. Numeric, 3 positions; optional. |
Item |
The code representing the item eligible for return. If the Display Item Alias (D56) system control value is selected, and if the customer ordered this item using an alias, the alias displays. Alphanumeric, 12 positions; optional. |
SKU |
The item's unique characteristics, such as its color or size. Only items on the order that are eligible for return display on this screen. To be eligible for return, there must be at least one unit that has been shipped and not fully returned and credited. If the Display SKU Description in place of SKU Element (F25) system control value is selected, the first 14 positions of the description of the SKU displays instead. Scanning on this field is not currently implemented. Alphanumeric, three 4-position fields; optional. |
Qty shipped |
The total quantity of the item that has been shipped to the customer. Numeric, 5 positions; display-only. |
Qty rtn'd (Quantity returned) |
The total quantity of the item that has been received at your warehouse as a return, either in a previous or in the current session. Numeric, 5 positions; display-only. |
Qty crdtd (Quantity credited) |
The total quantity of the item that has been fully returned and credited, either in a previous or in the current session. Numeric, 5 positions; display-only. |
RA pend (Return authorization pending) |
Indicates whether there is currently a return authorization in process for this item. Valid values are: • Selected = There is currently a return authorization in process for this item. This flag displays if a return was partially processed during a previous session or the current session, or if you have selected to fully process the return in the current session, but have not yet selected Accept to process the updates. • Unselected = There is not currently a return authorization in process for this item. |
Screen Option |
Procedure |
Display a return authorization in process |
Select Display for an item. Single return authorization: You advance to the Display RA Detail Screen if there is just one return authorization in process for the item. Multiple return authorizations: You advance to the Work with RA Detail for Item Screen. |
Begin a new return authorization against an item |
Select Create/process return for an item to advance to the Return/Exchange Item Screen (Creating a Return). |
Complete processing an existing return authorization against an item |
Select Complete/process return(s) for the item. Single return authorization: You advance to the Change RA Detail Screen (Complete/Process a Return for an Item) if there is just one return authorization in process for the item. Multiple return authorizations: You advance to the Work with RA Detail for Item Screen. |
Display order line history for an item |
Select Order line history for an item to advance to the Display Order Line History Screen. |
Create a misship return |
Select Create misship. See Create RA Detail Screen (Processing Misships). |
Advance to standard order inquiry |
Select Order Inquiry to advance to the Order Inquiry Header Screen or the Order Inquiry Detail Screen, depending on the setting of the Default Version for Order Inquiry (C34) system control value. |
Begin return authorization for all displayed items |
Select Create/Return all to advance to the Return/Exchange Item Screen (Creating a Return). |
Accept your entries |
Select Accept. See Accepting or Rejecting. |
Reject your entries |
Select Reject See Accepting or Rejecting. |
Work with additional charges for the order |
Select Additional Charges to display the Enter Additional Charges pop-up window. See Adding Miscellaneous Charges or Credits in Order Entry. Note: Additional charges bill the next time a transaction on the order (such as crediting a return) goes through billing. |
Create a tickler for the order, sold to customer on the order, and/or bill to customer on the order |
Select Create tickler to advance to the Create Tickler Screen. Note: To create a MN tickler, you must have authority to the Create Manual Tickler (B13) secured feature. |
Purpose: Use this screen to begin processing a return or exchange against an item. When you accept your entries against the order, the return authorization will be processed as far as your authority extends.
Note: You use the same screen when creating return authorizations for the entire order at once; however, its fields are different. See Return/Exchange Item Screen (Create/Return All).
How to display this screen: Select Create/process return for an item at the Work with Returns for Order Screen. If the item is not available for a new return authorization because a return authorization has been entered for each shipped unit already, the screen displays an error message:
No returns left to create - function not processed.
Returning an item with no primary location: You may receive returns for items which have no primary location, such as items you have previously liquidated and sold through an outlet store, or drop ship items which are returned directly to your drop ship vendor. For these items, if you have selected the Display "No Primary Location" Message in Returns (G46) system control value, the system displays a pop-up window indicating that a primary location for the item does not exist when you enter and validate an item as a return or a mis-ship.
This window is informational only. You can select Cancel to cancel the window, and then, if you wish, change the return disposition code before updating your entries and accepting/processing the return.
Note: This pop-up window displays only when you are posting a return for a single item; if you have advanced to the Return/Exchange Item screen selecting Create/Return all, the warning window does not appear, regardless of the setting in the Display "No Primary Location" Message in Returns (G46) system control value, or of whether any item on the order has no defined primary location.
Field |
Description |
Item |
The code representing the item you selected at the Work with Returns for Order Screen for return or exchange. If the Display Item Alias (D56) system control value is selected, and the customer ordered by alias, then the alias displays. This field does not display when you select Create/Return all to create/return all. Alphanumeric, 12 positions; display-only. |
SKU (Stock keeping unit) |
The item's unique characteristics, such as its size and color. This field does not display when you select Create/Return all to create/return all. Alphanumeric, three 4-position fields; display-only. |
Description |
The description of the item. This field does not display when you select Create/Return all to create/return all. Alphanumeric, 120 positions; display-only. |
RA # (Return authorization number) |
A number representing the return authorization. If you have authority to create, but not receive or credit, return authorizations, you create a new return authorization header record each time you create a return authorization for an item. Regardless of your authority level, however, one or more items would have the same return authorization number if you selected Create/Return all to return them all at once. This number consists of the order number, ship to number and return authorization number. Order number: numeric, 8 positions; display-only. Ship-to number: numeric, 3 positions; display-only. Return authorization number: numeric, 3 positions; display-only. |
Qty to return |
Enter the quantity of the item you are returning or exchanging to the same location and with the same return or exchange reason code. You cannot enter a number greater than the unreturned quantity that displays to the right. Time of update: The system does not post updates related to the quantity until you receive the return; so if you have create authority only, the operator who processes the receipt or receipt/credit can change the quantity. This field does not display when you select Create/Return all to create/return all. Numeric, 5 positions; required. |
Unreturned quantity |
The quantity of the item available to return. This is the quantity that is not included in another previous or current return. This field does not display when you select Create/Return all to create/return all. Numeric, 5 positions; display-only. |
Return reason |
The reason that the customer is returning the item or items. A return reason code indicates whether returned items are defective, and is used for reporting purposes. You must enter either a return reason code or an exchange reason code. You can use different return reason codes, or a mix of return reason codes and exchange reason codes, if you are processing returns against the same item but for different reasons. For example, if the customer is returning four units but one unit is damaged, you could process the return for that unit using a different return reason code. However, you cannot have more than one return in process for an item against the same location. |
Time of update: The system does not post updates that include the return reason code until you receive the return; so if you have create authority only, the operator who performs the receipt or receipt/credit can change the return reason at that time, or change from a return reason to an exchange reason. Return reason codes are defined in and validated against the Return Reason table. See Establishing Return Reason Codes (WRTR). Numeric, 3 positions; required if you do not enter an exchange reason code or when you select Create/Return all to create/return all. |
Exchange reason code |
The reason that the customer is exchanging the item. An exchange reason code indicates whether returned items are defective, and are used for reporting purposes. You must enter either a return reason code or an exchange reason code. If you enter an exchange reason code, you advance automatically to the Enter Exchange Item Screen or window depending on your authority level and the setting of the Require Exchange Item at Time of Receipt (F42) system control value. For example, if you have authority only to create a return authorization, not to return or credit, and if this system control value is selected, you will not need to enter an exchange item at this time. |
You can use different exchange reason codes, or a mix of return reason codes and exchange reason codes, if you are processing exchanges against the same item but for different reasons. For example, if the customer is exchanging four units but one unit is damaged, you could process the exchange for that unit using a different exchange reason code. However, you cannot have more than one return or exchange in process for an item against the same location. Retail pickup or delivery orders: This field is not available when you are working with a retail pickup or delivery order. See Maintaining Retail Pickup or Delivery Orders from the Order Broker for a discussion. |
Time of update: The system does not post updates that include the exchange reason code until you receive the return; so if you have create authority only, the operator who performs the receipt or receipt/credit can change the exchange reason at that time, or change from an exchange reason to a return reason. If you change from an exchange reason to a return reason and had already specified an exchange item, the exchange item will not be added to the order. This field is not available when you select Create/Return all to create/return all. Exchange reason codes are defined in and validated against the Exchange Reason table. See Establishing Exchange Reason Codes (WEXR). Numeric, 3 positions; required if you do not enter a return reason code. |
Return disposition |
A code that identifies how a returned item will be handled by the system, in terms of whether the return updates inventory and the warehouse and location to which the item will be returned. Required for return: You must enter a valid return disposition code when performing any type of return, such as a straight return, entering an exchange item, etc. The return disposition code defined in the Default Disposition Code (C18) system control value defaults, but you can override it. |
Affect inventory? If the return disposition code affects inventory (meaning that the item will be returned into active inventory and update the on-hand quantity in the specified location), the system requires the warehouse and location where the item will be returned. If the disposition code is set up to affect inventory and return to the primary location, the system will check for a primary location in the Item record. If one is available, the system will return the item automatically to this warehouse location. If one is not available or if the disposition code is not set up to receive returns in the primary location, the system will receive the return in the warehouse and location defined in the Return Disposition record; however, you can override these values to return the item to an alternate location. If the item/location does not exist, the system will create a record in the Item/Location table automatically. |
Regardless of whether the return disposition code specifies returning to the primary location, if the system control value Display "No Primary Location" Message in Returns (G46) is selected, and an item does not have a primary location, a pop-up window will display when you select OK to validate your entries and then select OK again to update the record; the pop-up window warns you that a primary location for the item does not exist. Select Cancel to cancel the window and either change the return disposition code, or select OK again to retain the disposition code you have already entered. |
Time of update: The system does not post updates that include the return disposition code until you receive the return; so if you have create authority only, the operator who performs the receipt or receipt/credit can change the return disposition code at that time. Authority: You can set up authority to process a return for a specific return disposition value at the user or user class level. This can be a blanket authority for all disposition values, or can be specific to individual codes. An error message indicates if you do not have authority to the return disposition code specified: User Does not have authority to return disposition code 4A.
Return disposition codes are defined in and validated against the Return Disposition Values table. See Establishing Return Disposition Values (WRDV). Alphanumeric, 2 positions; required. |
Warehouse |
The code representing the warehouse where the item is or items are being returned. When you are returning a single item, if there is a default warehouse and primary location specified for the item or SKU, the warehouse defaults here, but you can override it. If you are returning a single item, there must already be a record of the item in the warehouse you select. Time of update: The system does not post updates that include the warehouse until you receive the return; so if you have create authority only, the operator who performs the receipt or receipt/credit can change the warehouse at that time. Warehouse codes are defined in and validated against the Warehouse table; see Creating and Maintaining Warehouses (WWHS). Numeric, 3 positions; required if the return disposition value affects inventory. |
Location |
The code representing the location within the warehouse where the item is or items are being returned. If there is a default warehouse and primary location specified for the item or SKU, the location defaults here, but you can override it. Time of update: The system does not post updates that include the location until you receive the return; so if you have create authority only, the operator who performs the receipt or receipt/credit can change the location at that time. Location codes are defined in and validated against the Location table; see Creating and Maintaining Locations (WLOC). Alphanumeric, 7 positions; required if the return disposition value affects inventory. |
Indicates whether to refund freight to the customer when crediting the return. Valid values are: • Selected = Refund freight. If a Freight override amount is defined for the order and the Calculate freight field for the order ship to is selected, the system advances you to the Enter Freight Refund Window. • Unselected (default) = Do not refund freight. This field is enterable only if you have authority to the Receive Return Authorization (A29) secured feature. |
Indicates whether to refund any additional charges on the order to the customer when crediting the return. If there were negative additional charges billed on the order, refunding them results in adding positive addition charges, or decreasing the net amount of any refund. Valid values are: • Selected = Refund all additional charges on the order when crediting this return. • Unselected (default) = Do not refund additional charges. This field is enterable only if you have authority to receive return authorizations. |
Indicates whether to refund handling charges to the customer when crediting the return. Only handling charges related to the item(s) or units of the item(s) being returned are refunded. If the Evaluate Special Handling Charges by Order Line (D67) system control value is selected, handling charges are refunded only if you process a return against all units of the item on the order line. Valid values are: • Selected = Refund handling charges. • Unselected (default) = Do not refund handling charges. This field is enterable only if you have authority to receive return authorizations. |
Indicates whether to refund any duty charges for the returned item(s) or units to the customer when crediting the return. Valid values are: • Selected (default) = Refund duty charges. • Unselected = Do not refund duty charges. This field is enterable only if you have authority to receive return authorizations. |
Drop ship orders from multiple vendors: Order Management System does not allow you to create returns for multiple drop ship vendors at the same time. If you complete this screen for a second drop ship vendor on a single return, the system displays the following error message when you select OK: Returns against multiple drop ship items/vendors not allowed at the same time.
You must complete your return for the first vendor and create another return for each subsequent vendor on the order.
Processing returns through the integration with Order Broker’s Drop Ship Manager module is not currently implemented.
Completing the Return/Exchange Item Screen (Creating a Return)
Authority level: The system processes the updates as far as your authority extends. See Accepting or Rejecting for more information on the updates that take place when you select Accept based on your authority level.
No primary location warning: If the item does not have a primary location, the system displays an informational pop-up window when you select OK if the Display "No Primary Location" Message in Returns (G46) system control value is selected.
Scan Return ID window: If the Display Return ID Window (L99) system control value is selected, the system advances you to the Scan Return ID Window after you complete the required information on this screen and select OK. This window allows you to assign a return ID to the RA detail line in order to identify the return in an external system.
If you are not processing an exchange at this time, you return to the Work with Returns for Order Screen, where a message indicates how far the return was processed. Additionally, the Quantity shipped, quantity returned, quantity credited, and RA pending fields are updated appropriately.
If you make a mistake: If you have made a mistake on this screen and already selected OK, generally you cannot correct the return authorization in the current session. Instead, you must select Reject to reject your entries in the current session and reenter the return authorization for the item. See the description of the Delete option on the Work with RA Detail for Item Screen for the one exception.
Processing an exchange? Depending on your authority level and the setting of the Require Exchange Item at Time of Receipt (F42) system control value, you may need to enter an exchange item at this time if you entered an exchange reason code.
• If the Require Exchange Item at Time of Receipt (F42) system control value is selected, and if your authority extends at least to receiving a return authorization, you will need to enter an exchange item at this time.
• If the Require Exchange Item at Time of Receipt (F42) system control value is unselected, you will always need to enter an exchange item even if you have authority only to create a return authorization.
See Enter Exchange Item Screen.
Screen Option |
Procedure |
Select Create misship return. See Create RA Detail Screen (Processing Misships). |
Use this window to enter the freight amount to refund.
How to display this screen: This window displays if you select the Refund freight field on the Return/Exchange Item Screen (Creating a Return), a Freight override amount is defined for the order, and the Calculate freight field for the order ship to is selected.
Field |
Description |
Current freight amount |
The current freight amount for the order, based on the Freight override amount on the Display Order Properties Screen. Numeric, 20 positions with a 2-place decimal; display-only. |
Freight refund |
The amount of freight to refund. Freight tax override: If a Freight tax override is defined for the order, the system uses the Freight tax rate to calculate the amount of tax on freight to refund. Numeric, 7 positions with a 2-place decimal; required. |
Instructions:
1. Enter the amount of freight to refund in the Freight refund field.
2. Select OK. The system subtracts the freight refund amount from the current freight amount and updates the Freight override amount on the Display Order Properties Screen with the new Freight override amount. If a Freight tax override is defined for the order, the system uses the Freight tax rate to determine the new freight tax amount.
Example: You return a line on an order whose freight override amount is $10.00 and freight tax override amount is $2.50. The freight tax rate is 25%. At the Enter Freight Refund window, you enter $4.00 as the freight refund amount. Based on the freight refund amount, the system:
• Refunds $4.00 freight and $1.00 freight on tax.
• Updates the freight override amount to $6.00.
• Updates the freight tax override amount to $1.50.
Purpose: Use this screen to enter an exchange item and quantity to replace the returned item.
How to display this screen: This screen displays when you enter an exchange reason code at the Return/Exchange Item Screen (Creating a Return), depending on your level of authority and the setting of the Require Exchange Item at Time of Receipt (F42) system control value.
The Enter Exchange Item window may display instead, depending on whether you are processing a misship return, or the steps you use to create and process the return authorization. However, the window includes all the of same fields as the screen.
For more information: See Enter Exchange Item Screen in Working with Return Authorizations: Standard Process, for field descriptions and instructions on completing this screen.
Retail pickup or delivery orders: This screen is not available when you are working with a retail pickup or delivery order. See Maintaining Retail Pickup or Delivery Orders from the Order Broker for a discussion.
Purpose: Select Create/Return all at the Work with Returns for Order Screen to return all eligible items on the order as far as your authority extends. To be eligible, the item must have been shipped and must not currently have a return authorization completed or in process.
Not all options available: Although you advance to the Return/Exchange Item screen, the same screen you use to create individual return authorizations, you do not have all of the same options when you select Create/Return all to return all. For example:
• You cannot enter an exchange reason.
• You cannot specify item quantities.
• The system does not display informational pop-up windows informing you that an item has no primary location or that its primary location is frozen.
• The system does not display the Scan Return ID Window where you can assign a return ID to each RA detail line.
See Return/Exchange Item Screen (Creating a Return).
Completing returns: There is no equivalent option to complete processing all items on the order. If you select Create/Return all to return all but your authority does not extend all the way through receiving and crediting, another operator with greater authority can complete processing the returns by:
• selecting Complete/process return(s) for each individual item to complete processing; it is possible to change settings at this time if updates have not already taken place
• using Receiving Returns (WRAR) or Crediting Returns (WRAC) to complete processing.
How to display this screen: Select Create/Return all at the Work with Returns for Order Screen. If there are currently no items that have been shipped but have not yet had return authorizations created, the screen displays an error message.
Field descriptions: See Return/Exchange Item Screen (Creating a Return).
Completing this screen: The system processes the updates as far as your authority extends. See Accepting or Rejecting for more information on the updates that take place when you select Accept based on your authority level.
You return to the Work with Returns for Order Screen, where a message indicates how far the return was processed. Additionally, the Quantity shipped, quantity returned, quantity credited, and RA pending fields are updated appropriately for each item.
If you make a mistake: If you have made a mistake on this screen and already selected OK, you generally cannot correct the return authorization in the current session. Instead, you must select Reject to reject your entries in the current session and reenter the return authorization for the order. See the description of the Delete option on the Work with RA Detail for Item Screen for the one exception.
Purpose: Use this screen to complete or continue processing a return authorization that an operator without full authority created in an earlier session if your authority extends further. For example:
• the return authorization was created, and you have authority to create and receive, or create, receive and credit
• the return authorization was created and received, and you have authority to create, receive and credit
You can also use the Receiving Returns (WRAR) or Crediting Returns (WRAC) menu options to complete processing.
How to display this screen: You can display this screen by selecting Complete/process return(s) for a return authorization that is pending but not yet complete at the Work with Returns for Order Screen or the Work with RA Detail for Item Screen. You can also display this screen by selecting Accept at the Display RA Detail Screen.
If multiple returns: If there is more than one return authorization in process for the item you select, you advance to the Work with RA Detail for Item Screen when you select Complete/process return(s) for an item at the Work with Returns for Order Screen.
An error message indicates if there are no returns pending for the item, or if you do not have the authority to continue processing the return.
Field |
Description |
RA number |
A number representing the return authorization. You create a new return authorization header record each time you create a return authorization for an item. One or more items would have the same return authorization number if you selected Create/Return all to return them all at once. This number consists of the order number, ship to number and return authorization number. Order number: numeric, 8 positions; display-only. Ship-to number: numeric, 3 positions; display-only. Return authorization number: numeric, 3 positions; display-only. |
Line# |
The return authorization line associated with the return. The line number may be greater than 1 if you created the return authorization for all unreturned items on the order by selecting Create/Return all. Numeric, 3 positions; display-only. |
Item |
A code that identifies the unit of merchandise the customer is returning. Alphanumeric, 12 positions; display-only. |
The item's unique characteristics, such as its size and color. Alphanumeric, three 4-position fields; display-only. |
Order line# |
The number of the order line on which the item was ordered. Numeric, 3 positions; display-only. |
Invoice# |
A unique number to identify the invoice and the line number of the invoice on which the item was shipped and billed. Invoice number: numeric, 7 positions; display-only. Invoice line number: numeric, 3 positions; display-only. |
Refund freight |
Indicates whether to refund freight to the customer when crediting the return. Valid values are: • Selected = Refund freight. If a Freight override amount is defined for the order, the system advances you to the Enter Freight Refund Window. • Unselected (default) = Do not refund freight. This field is enterable only if you have authority to credit return authorizations. |
Refund add'l chgs (Refund additional charges) |
Indicates whether to refund any additional charges on the order to the customer when crediting the return. If there were negative additional charges billed on the order, refunding them results in adding positive addition charges, or decreasing the net amount of any refund. Valid values are: • Selected = Refund all additional charges on the order when crediting this return. • Unselected (default) = Do not refund additional charges. This field is enterable only if you have authority to credit return authorizations. |
Refund handling |
Indicates whether to refund handling charges to the customer when crediting the return. Only handling charges related to the item or units of the item being returned are refunded. If the Evaluate Special Handling Charges by Order Line (D67) system control value is selected, handling charges are refunded only if you process a return against all units of the item on the order line. Valid values are: • Selected = Refund handling charges. • Unselected (default) = Do not refund handling charges. This field is enterable only if you have authority to credit return authorizations. |
Refund duty charges |
Indicates whether to refund any duty charges for the returned item or units to the customer when crediting the return. Valid values are: • Selected (default) = Refund duty charges. • Unselected = Do not refund duty charges. This field is enterable only if you have authority to credit return authorizations. |
Qty to return (Quantity to return) |
Enter the quantity of the item you are returning or exchanging to the same location and with the same return or exchange reason code. This field is: • required if the return authorization has been created only and you are receiving, or receiving and crediting, at this time, as this information is required to process updates. • display-only if the return authorization has been created and received, and you are crediting at this time, as the related updates have already been processed. Numeric, 5 positions; required or display-only. |
Qty returned (Quantity returned) |
The quantity of the item that has been received into the warehouse on this return authorization only. Numeric, 3 positions; display-only. |
Qty credited (Quantity credited) |
The quantity of the item that has been credited on this return authorization only. This number should always be zero. Numeric, 3 positions; display-only. |
Return reason |
The reason that the customer is returning the item. A return reason code indicates whether returned items are defective, and are used for reporting purposes. You must enter either a return reason code or an exchange reason code to process a return authorization. You cannot have more than one return in process for an item against the same location. This field is: • required if you do not enter an exchange reason code, the return authorization has been created only, and you are receiving, or receiving and crediting, at this time, as this information is required to process updates. • display-only if the return authorization has been created and received, and you are crediting at this time, as the related updates have already been processed. Return reason codes are defined in and validated against the Return Reason table. See Establishing Return Reason Codes (WRTR). Numeric, 3 positions; required or display-only. |
The reason that the customer is exchanging the item. An exchange reason code indicates whether returned items are defective, and are used for reporting purposes. You must enter either a return reason code or an exchange reason code to process a return authorization. If you enter an exchange reason code, you advance automatically to the Enter Exchange Item Screen if this information was not already completed in an earlier session. You cannot have more than one return or exchange in process for an item against the same location. |
This field is: • required if you do not enter a return reason code, the return authorization has been created only, and you are receiving, or receiving and crediting, at this time, as this information is required to process updates. • display-only if the return authorization has been created and received, and you are crediting at this time, as the related updates have already been processed. Retail pickup or delivery orders: This field is not available when you are working with a retail pickup or delivery order. See Maintaining Retail Pickup or Delivery Orders from the Order Broker for a discussion. Exchange reason codes are defined in and validated against the Exchange Reason table. See Establishing Exchange Reason Codes (WEXR). Numeric, 3 positions; required or display-only. |
A code that identifies how a returned item will be handled by the system, in terms of whether the return updates inventory and the warehouse and location to which the item will be returned. This field is: • required if the return authorization has been created only, and you are receiving, or receiving and crediting, at this time, as this information is required to process updates. • display-only if the return authorization has been created and received, and you are crediting at this time, as the related updates have already been processed |
Regardless of whether the return disposition code specifies returning to the primary location, if the system control value Display "No Primary Location" Message in Returns (G46) is selected, and an item does not have a primary location, a pop-up window will display when you select OK to update the record; the pop-up window warns you that a primary location for the item does not exist. Select Cancel to cancel the window. If you are receiving the item, or receiving and crediting, you can change the return disposition code if you wish. Otherwise, select OK again to retain the code already entered. See Return/Exchange Item Screen (Creating a Return). Return disposition codes are defined in and validated against the Return Disposition Values table. See Establishing Return Disposition Values (WRDV). Alphanumeric, 2 positions; required or display-only. |
Warehouse |
The code representing the warehouse where the item is being returned. If there is a default warehouse and primary location specified for the item or SKU, the warehouse defaults here, but you can override it. There must already be a record of the item in the warehouse you select. This field is: • required if the return disposition value affects inventory, if the return authorization has been created only, and you are receiving, or receiving and crediting, at this time, as this information is required to process updates. • display-only if the return authorization has been created and received, and you are crediting at this time, as the related updates have already been processed. Warehouse codes are defined in and validated against the Warehouse table; see Creating and Maintaining Warehouses (WWHS). Numeric, 3 positions; required or display-only. |
Location |
The code representing the location within the warehouse where the item is being returned. If there is a default warehouse and primary location specified for the item or SKU, the location defaults here, but you can override it. This field is: • required if the return disposition value affects inventory, if the return authorization has been created only, and you are receiving, or receiving and crediting, at this time, as this information is required to process updates. • display-only if the return authorization has been created and received, and you are crediting at this time, as the related updates have already been processed. Location codes are defined in and validated against the Location table; see Creating and Maintaining Locations (WLOC). Alphanumeric, 7 positions; required or display-only. |
• If the item does not have a primary location, the system displays an informational pop-up window when you select OK if the Display "No Primary Location" Message in Returns (G46) system control value is selected.
• The system processes the updates as far as your authority extends. See Accepting or Rejecting for more information on the updates that take place when you select Accept based on your authority level.
• If you are not processing an exchange at this time, you return to the Work with Returns for Order Screen, where a message indicates how far the return was processed. Additionally, the Quantity shipped, quantity returned, quantity credited, and RA pending fields are updated appropriately.
If you make a mistake: If you have made a mistake on this screen and already selected OK, you cannot correct the return authorization in the current session. Instead, you must select Reject to reject your entries in the current session and reenter the return authorization for the item.
Purpose: Use this screen to review a return authorization that is in process for an item. From this screen, you can also:
• Display the RA Exchange Item Window, which includes information on the exchange item for the return, if any.
• Advance to the Change RA Detail Screen (Complete/Process a Return for an Item), where you can continue processing the return authorization.
• Select Display for an item at the Work with Returns for Order Screen (streamlined process)
• Select Display for a return authorization at the Work with Return Authorization Detail Screen (standard process)
• Select Display for an item at the Second Process RA Credits Screen (Crediting Returns (WRAC))
If multiple returns: If there is more than one return authorization in process for the item you select, you advance to the Work with RA Detail for Item Screen instead.
Purpose: Use this window to review information on the item to ship in exchange for a returned item.
How to display this window: Select Exchange Info at the Display RA Detail Screen. If there is not an exchange item to be shipped for the return, the screen displays an error message.
Field descriptions: See Enter Exchange Item Screen.
Purpose: Use this screen to review return authorizations for an item if there is more than one authorization in process, or to delete a return authorization which has not yet been received and credited.
How to display this screen: Select Display or Complete/process return(s) for an item at the Work with Returns for Order Screen if there is more than one authorization in process.
Field |
Description |
Date created |
The date the return authorization was created. Numeric, 6 positions (in user date format); display-only. |
Screen Option |
Procedure |
Delete a return authorization |
Select Delete for a return authorization to delete it. Note: You can delete a return authorization record only you have the proper authority, as controlled by the Delete Return Authorizations (B03) secured feature, and if the return has not yet been received. However, if you have received the return and not yet accepted your entries, you can reject the entries in the current session, then reselect the return authorization and delete the item. |
Review a return authorization in process for the item |
Select Display for a return authorization to advance to the Display RA Detail Screen. |
Continue processing a return authorization for the item |
Select Complete/process return for a return authorization to advance to the Change RA Detail Screen (Complete/Process a Return for an Item). |
Pick slip preparation: When you accept or reject a return authorization, the system determines if the order qualifies for pick slip preparation and applies it to the order. If you add an exchange item to the order, the system performs pick slip preparation for the exchange item when you receive the return authorization. See Preparing Orders for Pick Slip Generation.
Select Accept to accept all of your entries during the current session while Working with Return Authorizations: Streamlined Process. Depending on your authority, the updates made at this point are as follows:
• Create a Return Authorization
• Receive a Return Authorization
• Credit a Return Authorization
A message is written to order history:
Order was maintained through R/A.
Note that the dollar amount that displays with this message refers to the entire order total, not just the dollar value of any return.
If the return authorization was created through the e-commerce interface: You can enable your web customers to create return authorizations on the storefront. When a return authorization is created through this method, a message such as the following is written to order history:
7/14/06 N RA 5525-1-1 created from the web.
Note that this message does not include a dollar amount or user ID.
You can review these messages by selecting Messages in standard order inquiry to advance to the Display Order History Screen. These messages are also available by selecting Messages in streamlined order inquiry.
Receipts are processed through the ORDR_ASYNC job. Updates include:
• The inventory for the item, including increasing on-hand in the item location and item warehouse, and adding an inventory transaction history record
• the order, including the order detail and order line history
• for an exchange, adds the exchange item to the order
• the return authorization header and detail
Credits are processed through the ORDR_ASYNC and BILL_ASYNC jobs, which update:
• the order, including order history, and creating the credit invoice and refund, if appropriate
• the return reason or exchange reason history for the offer
• the return authorization header, deleting the detail record.
Note: Refunds can be either positive (you owe the customer money) or negative (the customer owes you money).
Select Active Pay Method screen: The system displays the Select Active Pay Method screen when you accept the return authorization if a deactivated payment method exists on the order. Use this screen to select which active payment method will receive the credit.
Select Reject to reject all of your entries during the current session. Any updates to the return authorization tables will be undone, and additional updates will not take place.
To undo an error you made while processing a return authorization against any of items during the current session, you must reject all entries. You cannot undo an individual return authorization.
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
