Pages Used for the PeopleSoft Fluid Simple Journal Entry
| Page Name | Definition Name | Usage |
SJ_JRNL_ENTRY_FL |
Access the Simple Journal page in PeopleSoft Fluid. |
SJ_JRNL_ENTRY_FL |
View or enter journals associated with a particular Business Unit. |
SJ_JRNL_HDR_SRC_FL |
Review and edit the journal header details. |
SJ_JRNL_HDR_CUR_FL |
Review and edit currency details for the selected journal. |
SJ_JRNL_LN_FL |
Review journal lines and edit details for the selected journal. |
SJ_JRNL_TOTALS_FL |
Review and edit journal totals. |
SJ_JRNL_COMMIT_FL |
Review and edit commitment control amount details. |
SJ_JRNL_ATTACH_FL |
View, modify or attach files to the selected journal. |
SJ_JRNL_APPR_FL |
View approval status of the selected journal. |
