Cabling Requirements
Read the following cable requirements for connecting the server.
  • Minimum cable connections for the server:
  • SP management ports:
    The server includes two management ports for use with the Oracle ILOM service processor (SP).
    • The serial management port (SER MGT) is the default connection to the Oracle ILOM SP. The SP serial management port uses an RJ-45 cable and is always available for a CLI connection. See SER MGT Ports.
    • The network management port (NET MGT) is the optional connection to the Oracle ILOM SP. The SP network management port uses an RJ-45 cable for a 100/1000 BASE-T connection. See NET MGT Port.
  • NET Ethernet ports:
    The Oracle Communications Server E6-2L back panel includes four Ethernet network ports, labeled NET MGT, NET 0, and two QSFP 28/56 GbE Ethernet connectors for the Ethernet controller that connects the server to the network. The server Ethernet interfaces operate at 1000 Mbps, and 10,000 Mbps.
    • NET 0: 100/1000BASE-T RJ-45 GbE port
    • OCPNIC QSPF: Two QSFP 28/56 GbE Ethernet connectors for the Ethernet controller. (Optional) 10/25/50/100/200 Gbs Open Compute Project (OCP) Version 3.0 (V3) Network Interface Card (NIC) with two QSFP ports (PORT 1 and PORT 2).
    The Oracle Communications Server E9-2L back panel includes two network Ethernet ports, labeled NET MGT, NET 0 that connect the server to the network. The server Ethernet interfaces operate at 100 Mbps (Oracle Communications Server E6-2L only), 1000 Mbps, and 10,000 Mbps.
  • USB Ports: The server USB ports support hot-plug insertion and removal. You can connect and disconnect USB cables and peripheral devices while the server is running without affecting server operations.
    See USB Port.
  • AC power cables: The server has two power supply connectors, one for each power supply.
    See Connect Cables and Power Cords.
