4.399 rept-stat-clk
Use this command to display the clock status summary for cards in the system.
Parameters
Example
rept-stat-clk
rept-stat-clk:mode=full
Dependencies
No other rept-stat-xxx
command can be in progress when this command is entered.
Notes
The clock status report includes the status of all the clocks in the system (Clock A, Clock B, Clock I, High Speed (HS) Clock A, HS Clock B, etc.).
The Time Slot Counter Synchronization (TSC) clock appears only if the Time Slot Counter Synchronization (TSCSYNC) feature is turned on. See the chg-feat
command.
The Composite clock sections of the report are the Primary Comp Clock (CLK) and Secondary Comp CLK fields in the COMPOSITE SYSTEM CLOCK section: the summary of the number of cards having bad status or using COMP CLKs: and the CLK columns in the "Cards with bad clock source" section that appears when the mode=full parameter is specified.
The HS clock sections of the report are the Primary HS Clock (CLK), Secondary HS CLK, HS CLK TYPE, and HS CLK LINELEN fields in the HIGH SPEED SYSTEM CLOCK section: the summary of the number of cards having bad status or using HS CLKs: and the HS CLK columns in the "Cards with bad clock source" section that appears when the mode=full parameter is specified.
HS clock capable cards can support a link that is provisioned to use HS Master Timing. These cards include all cards with type LIME1 or LIMT1 and all cards that run the ATMANSI or ATMITU applications. The clock status values are the same as those listed in the rept-stat-card:mode=full:loc=xxx
report.
For a complete list of the cards and their applications, see Table A-9 .
If HS clock A and B status is included in the "Cards with bad clock source" section, then cards that cannot be provisioned to use HS Master Timing display dashes for HS clock A and B status.
The PST/SST for the Primary Composite Clock (Comp Clk) 1114, Primary Comp Clk 1116, Secondary Comp Clk 1114, Secondary Comp Clk 1116, Primary HS Clk 1114, Primary HS Clk 1116, Secondary HS Clk 1114, and Secondary HS Clk 1116 can be one of the following values:
- IS-NR/active—clock source is valid, clock chosen as source
- IS-NR/idle—clock source is valid, clock not chosen as source
- OOS-MT/fault—clock source is invalid
The PST/ SST for the Composite System Clock and High Speed System Clock can be one of the following values:
- IS-NR/Idle—all cards showing good clock, clock not required
- IS-ANR/Idle—some cards showing bad clock, clock not required
- OOS-MT/Idle—all cards showing bad clock, clock not required
- IS-NR/Active—all cards “requiring clocks” showing good clock, clocks required
- IS-ANR/Fault—some cards “requiring clocks” showing bad clock, clocks required
- OOS-MT/Fault—all cards “requiring clocks” showing bad clock, clocks required
An asterisk (*) indicates that the card requires the indicated clock.Output
A TDM card can use a local clock that is generated independently on each TDM as a clock source for the corresponding internal system clock. The system does not report the “cards bad” status for these internal clocks.Note:
The use of HS CLK I is not automatic when both the high-speed primary and secondary clocks are invalid. An E5-ATM-B card must be provisioned (using theent-slk:atmtsel=internal
command) to use the high-speed
internal clock.
The Using field in the Composite Clock section describes all of the cards that are using the Composite Clock, not just HS clock capable cards. rept-stat-clk
tekelecstp 08-06-07 14:40:13 EST EAGLE 39.0.0
COMPOSITE PST SST AST
SYSTEM CLOCK IS-NR Idle -----
ALARM STATUS = No Alarms.
Primary Comp Clk 1114 (CLK A) IS-NR Active -----
Primary Comp Clk 1116 (CLK B) IS-NR Active -----
Secondary Comp Clk 1114 (CLK A) IS-NR Idle -----
Secondary Comp Clk 1116 (CLK B) IS-NR Idle -----
Clock Using Bad
CLK A 2 0
CLK B 0 0
CLK I 0 --
HIGH SPEED PST SST AST
Primary HS Clk 1114 (HS CLK A) IS-NR Active -----
Primary HS Clk 1116 (HS CLK B) IS-NR Active -----
Secondary HS Clk 1114 (HS CLK A) IS-NR Idle -----
Secondary HS Clk 1116 (HS CLK B) IS-NR Idle -----
HS CLK TYPE 1114 = RS422
HS CLK LINELEN 1114 = -----
HS CLK TYPE 1116 = RS422
HS CLK LINELEN 1116 = -----
Clock Using Bad
HS CLK A 0 0
HS CLK B 0 0
HS CLK I 0 --
Command Completed.
The following example shows output when two GPSM-II cards are configured and an HS clock
capable card is configured. The TSCSYNC feature is not turned on. rept-stat-clk
Clock Using Bad
CLK A 3 0
CLK B 0 0
CLK I 0 --
SYSTEM CLOCK IS-NR Active -----
Clock Using Bad
HS CLK A 1 0
HS CLK B 0 0
HS CLK I 0 --
Command Completed.
The following example shows output when two GPSM-II cards are configured and HS clock
capable cards are not configured. The TSCSYNC feature is turned on. rept-stat-clk
tekelecstp 08-05-07 14:40:13 EST EAGLE 39.0.0
Clock Using Bad
CLK A 2 0
CLK B 0 0
CLK I 0 --
Prefer Clock A for TSC CLOCK
Clock Using Bad
HS CLK A 0 0
HS CLK B 0 0
HS CLK I 0 --
Command Completed.
capable card is configured. The TSCSYNC feature is turned on. rept-stat-clk
Clock Using Bad
CLK A 3 0
CLK B 0 0
CLK I 0 --
Clock Using Bad
HS CLK A 1 0
HS CLK B 0 0
HS CLK I 0 --
Command Completed.
The following example shows output when the mode=full
parameter is specified and HS clock capable cards are configured. The TSCSYNC feature is
turned on.
SYSTEM CLOCK IS-ANR Fault -----
Primary Comp Clk 1116 (CLK B) ----- ----- -----
Secondary Comp Clk 1116 (CLK B) ----- ----- -----
Clock Using Bad
CLK A 4 1
CLK B 0 5
CLK I 0 --
SYSTEM CLOCK OOS-MT Fault -----
Primary HS Clk 1116 (HS CLK B) ----- ----- -----
Secondary HS Clk 1116 (HS CLK B) ----- ----- -----
HS CLK TYPE 1114 = E1 UNFRAMED
HS CLK LINELEN 1114 = SHORTHAUL
HS CLK TYPE 1116 = -----
Clock Using Bad
HS CLK A 0 1
HS CLK B 0 1
HS CLK I 0 --
Cards with bad clock source:
CARD CLK A CLK B HS CLK A HS CLK B
1103 *Active *Fault ------ ------
1104 Active Fault *Fault *Fault
1106 *Active *Fault ------ ------
1113 Active Fault ------ ------
1205 Fault Fault ------ ------
Command Completed.
The following example shows output when HS clock capable cards are not configured. The
rept-stat-clk
Clock Using Bad
CLK A 3 0
CLK B 0 0
CLK I 0 --
Clock Using Bad
HS CLK A 0 0
HS CLK B 0 0
HS CLK I 0 --
Command Completed.
Legend
- COMPOSITE SYSTEM CLOCK—Composite System clock status
- ALARM STATUS—System clock alarms; "No alarms" is shown when there are no alarms.
- PRIMARY COMP CLK—The status of the primary Composite clock input for a particular TDM
- SECONDARY COMP CLK—The status of the secondary Composite clock input for a particular TDM
- CLK A – Internal Eagle Clock sourced by the 1114 TDM from the selected clock source.
- CLK B – Internal Eagle Clock sourced by the 1116 TDM from the selected clock source.
- CLK I – Local clock generated independently on each LIM card.
- Prefer CLOCK x for TSC CLOCK—The preferred clock source of the Time Slot Counter Synchronization (TSC) clock; appears only when the TSCSYNC feature is turned on.
- HIGH SPEED SYSTEM CLOCK—HS system clock status
- ALARM STATUS—HS System clock alarms; "No alarms" is shown when there are no alarms.
- PRIMARY HS CLK—The status of the high-speed primary clock input for a particular TDM
- SECONDARY HS CLK—The status of the high-speed secondary clock input for a particular TDM
- HS CLK TYPE—HS clock source (see the chg-stpopts command) for a particular TDM
- HS CLK LINELEN—HS clock line length (see the chg-stpopts command) for a particular TDM
- HS CLK A – Internal Eagle High Speed Clock sourced by the 1114 TDM from the selected clock source.
- HS CLK B – Internal Eagle High Speed Clock sourced by the 1116 TDM from the selected clock source.
- HS CLK I – Local clock generated independently on each LIM card. The value for the internal high-speed clock (Cards using HSCLK I) is generated differently from the internal system clock (Cards using CLK I). The internal high speed clock is generated by the XILINX on the ATM applique’s card. The internal system clock is generated by the Xilinx on the LIM main board when the LIM card does not have a valid system clock source (e.g., both A system clock and B system clock are bad at the LIM card).
