Oracle Utilities Customer Cloud Service Integration to Oracle Utilities Digital Asset Cloud Service Configuration Guide
Overview
Overview of the Integration
About Oracle Utilities Customer Cloud Service
About Oracle Utilities Digital Asset Cloud Service
About Oracle Integration Cloud
Software Requirements
Prerequisites
Supported Business Processes
Solution Architecture
Solution Overview
One-way Asynchronous
Solution Diagram
Integration Flows
Customer Sync (Oracle Utilities Customer Cloud Service Initiated)
Common Integration Flows
File to File Transfer
Common Child File Transfer Flows (Oracle Integration Cloud Initiated)
Common Error Handler (Oracle Integration Cloud Initiated)
Configuring Oracle Utilities Customer Cloud Service
Configuring Admin Data
Feature Configuration
Maintenance Object Audit Configuration
Scheduling the Batch Process
Initial Load
Incremental Load
Adding Oracle Integration Cloud Certificates
Configuring Oracle Utilities Digital Asset Cloud Service
Message Senders
External System
Sync Admin Data
Acknowledgement Configuration
Upload File
Transition Sync Request
Load Data (Only for Initial Load)
Sequence of Events for Customer Data Upload
Importing, Configuring, and Testing Integration Connections
Importing the Oracle Integration Cloud Package from Oracle Cloud Marketplace
Verifying the Package Import
Configuring Connections in Oracle Integration Cloud
OU FTP CCS for CCS-DACS Connection
OU REST CCS OS for CCS-DACS Connection
OU FTP DACS for CCS-DACS Connection
OU REST DACS for CCS-DACS Connection
OU REST CCS for CCS-DACS Connection
OU REST for CCS-DACS Connection
OU REST OIC for CCS-DACS Connection
Configuring Agent (if applicable)
Possible Combinations
Creating an Agent Group
Downloading Agent Installer
Installing On-Premises Agent
Setting up Certificates for Security
Configuring Lookups, Error Handling, and Email Notifications
Configuring Lookups
Editing Lookups
Error Handling
Summary of Integration Error Handling
Resubmitting the Error Instances in Oracle Integration Cloud
Email Notifications
Customizations
Adding New Mappings
Activating and Testing the Integration Flows
Activating Integration Flows
Monitoring and Troubleshooting
Oracle Utilities Customer Cloud Service Error Logs
Monitoring Integration Flows
Troubleshooting
Limitations and Workarounds
Oracle Utilities Customer Cloud Service Integration to Oracle Utilities Digital Asset Cloud Service Release 23C Configuration Guide
