Examples of Lamp-Oriented Service Investigation Activity Types and their Steps
The following table shows several classic lamp-oriented activity types and their respective steps:
 Activity Type  |
 Step  |
 Step Type Action  |
 Retire lamp and install another  |
 Remove lamp  |
 Remove Item  |
 Define lamp's retirement date  |
 Change Item  |
 Install lamp  |
 Install Item  |
 Lamp service investigation order  |
 Check service point - optional  |
 Change Service Point  |
 Remove lamp - optional  |
 Remove Item  |
 Check lamp attributes - optional  |
 Change Item  |
 Install lamp - optional  |
 Install Item  |
 Contact customer - optional  |
 Contact Customer  |
