Defining Entity Groups
You use the Entity Group portal to display and maintain entity groups.
Refer to Understanding Entity Groups for more information.
You can access the portal by selecting Admin, select General, then select Entity Group. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Entity Group: This zone displays basic information about entity group.
- Eligible Devices for this Group: This zone shows a list of devices that are eligible for assignment to this entity group. The list is based on the Template SQL on the Group Category with the Criteria Values applied. To assign one or more devices to the group, select the devices and click Assign. Applicable only for "Device" entity groups.
- Devices in this Group: This zone shows a list of devices that have been assigned to this entity group. To delete the relationship between the device and the entity group, select the device and click Delete. To expire the relationship between the device and the entity group, select the device and click Expire. Applicable only for "Device" entity groups.
- Eligible Service Points for this Group: This zone shows a list of service points that are eligible for assignment to this entity group. The list is built from the Template SQL on the Group Category with the Criteria Values applied. To assign one or more service points to the group, select the service points and click Assign. Applicable only for "Service Point" entity groups.
- Service Points in this Group: This zone shows a list of service points that have been assigned to this entity group. To delete the relationship between the service point and the entity group, select the device and click Delete. To expire the relationship between the service point and the entity group, select the device and click Expire. Applicable only for "Service Point" entity groups.
Batch Processing
The Device Group Evaluation (D1-DGEV) and Service Point Group Evaluation (D1-SPGEV) batch controls are used to identify devices or service points (respectively) that are eligible for a particular group and assigns them to a specified group, or expires relationships between devices or service points (respectively) and a specified group.
Devices or service points that are not currently assigned to an entity group for a specified category will be assigned to an eligible group. Only one group for the category may be assigned. If the device or service point is currently assigned a group for that category, it will be evaluated for eligibility, and if the current group is no longer eligible, the group is expired. If the same device becomes eligible for another group, that group is assigned to the device or service point.
Parameters:
Group Code Category: A group category used to identify eligible entities. Required if the Mode is "Evaluate Group Code Category"
- Group Code: A group used to identify eligible entities, Required if the Mode is "Expire Device Group Code", "Expire Service Point Group Code" or "Evaluate Group Code", and is optional if the Mode is "Evaluate Group Code Category".
Mode (Required): The mode by which the process evaluates entities.
Options include:
- Expire Device Group Code (D1ED): Used to expire device entity group relationships for the specified Group Code
- Expire Service Point Group Code (D1ES): Used to expire service point entity group relationships for the specified Group Code
- Evaluate Group Code (D1EG): Used to search entities based on Group Code, and assigns eligible devices or service points to the specified Group Code
- Evaluate Group Code Category (D1GC): Used to search entities based on Group Code Category (and optionally a Group Code). This mode assigns devices or service points eligible for a group of the specified category (and Group Code if provided), and expires relationships between devices or service points and groups of the specified category (and Group Code is provided).
Note that these batch controls are used with groups whose Group Assignment Option is either "System" or "System or User".
