Defining Program Rules
You use the Program Rule portal to display and maintain program rules.
Refer to Understanding Program Rules for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Program Rule.
Program Rule List: This zone lists all program rule records. Broadcast a record to display the details of the selected record.
Program Rule: This zone displays the selected program rule.
