Defining Service Codes
You use the Service Code - CCB portal to display and maintain service areas.
Refer to Understanding Service Codes for more information.
To access the portal select Admin, select Field Work, then select Service Code - CCB.
Service Code List: This zone lists all service codes defined in the system. Broadcast a record to display the details of the selected record.
Service Code: This zone displays the selected service code.
