Defining Postal Code Defaults
You use the Postal Code Default portal to display and maintain postal code defaults.
Refer to Understanding Postal Code Defaults for more information.
You can access the portal by selecting Admin, select Geographic, then select Postal Code Default - MDM.
  • Postal Code Default List: This zone lists all postal code defaults defined in the system. Broadcast a record to display the details of the selected record.
  • Postal Code Default: This zone displays the selected postal code default.
  • Postal Code Default Characteristics: This zone displays characteristics for the selected postal code default.
Batch Processing
The Data Export D1_​POSTAL_​DFLT (D1POSTTX) batch process can be used to export postal code default data when and as needed. Use the Batch Control portal to view the parameters used by this batch process.
