Defining DER Aggregators
You use the DER Aggregator portal to display and maintain Distributed Energy Resource (DER) Aggregators.
Refer to Understanding DER Aggregators for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select DER Aggregator.
DER Aggregator List: This zone lists all DER aggregator records. Broadcast a record to display the details of the selected record.
DER Aggregator: This zone provides information about the selected aggregator.
Processing Method List: This zone provides the list of processing methods defined for the aggregator.
